Thread: Jetta CL 1.9 BHP Rating
  1. Jetta CL 1.9 BHP Rating
    peterwatkins99 Guest
    looking at a Vento as a cheap option to a bora - read recently that the Vento 1.9 CL diesel had just 75BHP. is this correct? seems miserly when u think even the small diesel golfs have 90+ BHP
    a misprint perhaps?
  2. Re: Jetta CL 1.9 BHP Rating
    Aug 2007
    Northern Ireland
    most "small diesel golfs" have turbos bolted on You are comparing apples with oranges
    Jetta CL equivalent in the Golf would be the SDI or similar, which is also 75BHP
    If you want much more than 75BHP from a 2L diesel you will need a turbo diesel
  3. Re: Jetta CL 1.9 BHP Rating
    not a reprint at all
    most diesels without turbos are useless, the SDi golf for example only pushes arond 70/80 bhp, thats from a 1.9 diesel.
    if you want more power, you're going to need a Tdi.
  4. Re: Jetta CL 1.9 BHP Rating
    Aug 2007
    Northern Ireland
    Is there an echo in here?
  5. Re: Jetta CL 1.9 BHP Rating
    cheers lads (& ladies?) i'll make sure i go for a TD!
  1. Jetta SE
    By jenny in forum New Member Introductions
    Last Post: 17-12-2007, 02:19 PM
  2. RCD 300 in Jetta
    By theblackbag in forum Jetta MK3 - 2005 - 2013
    Last Post: 17-08-2007, 07:47 PM
  3. Need some help about the VW A5 jetta 1.4
    By khaledmma in forum Jetta MK3 - 2005 - 2013
    Last Post: 12-03-2007, 02:02 AM
  4. Correct load rating for a 97 Jetta III
    By vc12 in forum Golf - Jetta - Vento - Bora - Archive Topics
    Last Post: 26-09-2006, 06:22 PM
