SO THE ENGINNER SPENT 5HRS CHECKING CAR. aLLSEALS OK, TURBO OK ..TOOK SPARK PLUGS OUT AND EACH ONE WET. (soz didnt mean to use capitals!)
Emissions ok and a little amount of smoke in back. Took it out and like a new car! So why the oil consumption. Could it be the sensor is wrong in the car and ) on the MMI could really be 100%! so is it burning excess oil and the film on the pistons is carry over from the cam rod ? He put his stick in 585mm (numbr from another forum) and has 4" on the stick!!
Can it run with 8litres of oil instead of 6.5? If i ignore the " please add 1 quart" alarm is there a low low level alarm?
