Thread: Xenon light retrofit led daylight running ?!?!
  1. Xenon light retrofit led daylight running ?!?!
    Dec 2012
    Ipswich
    Hi all I've retro fitted the xenon lights all coded they work great but I want to fit LEDs for the daylight running but the canbus keeps bringing up the bulb fault (mainbeam) guessing that's the circuit there on the LEDs mount up to 50w so errr anyone ???
  2. Re: Xenon light retrofit led daylight running ?!?!
    Jan 2012
    Coding Something
    Sorry but your post is a bit confusing, you've fitted oem bixenons, they work 100% but you get mainbeam fault on the dis, is this with led's already fitted or not yet?
  3. Re: Xenon light retrofit led daylight running ?!?!
    Dec 2012
    Ipswich
    With the LEDs fitted
  4. Re: Xenon light retrofit led daylight running ?!?!
    Jan 2012
    Coding Something
    If its giving you main beam errors, then seems it still thinks your bixenons are halogens as the led is plumbed into where main beam would be, check your coding is correct for oem bixenons, as for led's well I only invested in interior ones but headlights & rears, cant be bothered as more trouble than worth sometimes.
  5. Re: Xenon light retrofit led daylight running ?!?!
    Dec 2012
    Ipswich
    All sorted I just needed a load resistor on each led .
  1. LED Daylight Running Lights......
    By srisport in forum Passat CC
    Last Post: 20-09-2012, 11:02 AM
  2. Question Aftermarket upgrade to Xenon headlamp with LED daylight running lights
    By andropod in forum Audi A4 - B8 Forum - 2008 - 2015
    Last Post: 10-11-2010, 03:00 PM
  3. Emergency!! Led Strip Sidelight Daylight Running
    By Shipz in forum Bora - 1998 - 2005
    Last Post: 17-02-2009, 10:11 PM
  4. LED Daylight Running Lights
    By Stonkn in forum Audi A3 - Archive Topics
    Last Post: 18-12-2007, 12:49 PM
  5. White LED Daylight Running Lights ?
    By sbuk73 in forum Audi A4 - B6 Forum - 2002 - 2005
    Last Post: 20-07-2007, 05:51 PM
