Thread: Torque wrench figure??
  1. Torque wrench figure??
    Aug 2007
    South Hams, Devon
    Does anyone have the torque figure for the 5x Bolts that hold the rear hub to the trailing arm? I am changing mine tomorrow!
    1999 VW Passat 1.9 Tdi Sport 110Bhp Bio-fuel
    Land Rover 110 200Tdi CSW Bio-fuel
    RRC 3.5EFI...Toy
  2. Re: Torque wrench figure??
    Aug 2007
    South Hams, Devon
    Anyone?
    RRC 3.5EFI...Toy
  3. Re: Torque wrench figure??
    Aug 2007
    I don't know what the figure is but a good way is to use a dial type torque wrench when you take it apart in order to measure the torque.
  4. Re: Torque wrench figure??
    Big G Guest
    Quote Originally Posted by L90OOK View Post
    I have just bought a new passat haynes manual. I dont have it with me now but i can get the data for you tomorrow if thats any help? Let me know
  5. Re: Torque wrench figure??
    Oct 2005
    Quote Originally Posted by Someone on another forum
    I replaced the rear hub tonight. The new bolt vs re-use issue was resolved with a surprise -- getcoolparts included replacement bolts in the package! BTW, I did call the dealer and they stated that they do not replace but rather re-use the bolts. Total cost was $110 with 2-day shipping and about an hour+ of my time.
    how to:
    - jack up car and place on jack stands
    - remove wheel
    - remove caliper, pads, and rotor (see excellent how-to on this site)
    - use wire or bungy cord to support caliper
    - crawl under car and remove ABS sensor from back of hub. There is a plastic clip that you remove first. Then use a small flat blade screw driver to gently pry out the sensor.
    - rotate the hub so that the large holes line up with the 5 bolts
    - Use an 8mm socket on an extension (I used a 6") to remove the bolts and the hub.
    - Installation is the reverse. Torque bolts to 60 Nm.
    - Hardest part for me was getting the ABS sensor all the way back into the hub, its a tight fit.
    - Will need to retract caliper piston to get caliper and pads back on per the how-to, use the right tool (I used the rental brake kit from Advance that included an 8mm socket).
    So 60 Nm looks like the value
  6. Re: Torque wrench figure??
    Aug 2007
    South Hams, Devon
    Many thanks for that...I was going to do about 65Nm
    Not a good way to check torque figures...the bolts are thread locked on & have 8 years of corrosion & muck to break first.
    RRC 3.5EFI...Toy
  1. CVT max power/torque
    By A6_JAck in forum Audi A6 - C5 Forum - 1998 - 2004
    Last Post: 23-08-2007, 01:50 PM
  2. torque settings
    By jimbob in forum Golf - Jetta - Vento - Bora - Archive Topics
    Last Post: 17-07-2007, 06:23 PM
  3. P-Torque Rolling Road Day
    By p-torque.co.uk in forum Archive posts
    Last Post: 07-06-2007, 03:52 PM
  4. Porsche Torque
    By msond in forum Reviews & Recommendations of Dealers & Independant Garages
    Last Post: 23-02-2005, 08:22 PM
