Thread: Brake disc retaining screw size
  1. Brake disc retaining screw size
    mjhamilton Guest
    So whilst removing my wheels to clean my arches I found that some sloppy spanner monkey didn't bother to put the brake disc retaining screws back in so it makes it a little fiddly to refit the wheels as the discs can rotate on the hub and cover the bolt holes..
    Just wanted to see if anyone knows the corrected sized screw for here - my gut tells me stainless steel m6 (6mm) x 16mm countersunk bolts with hex heads will be perfect but sometimes it is wrong....
    Anyone confirm?
    Thanks in advance
  2. Re: Brake disc retaining screw size
    Sep 2011
    Lurking over a keyboard ...
    Yes mate you're spot on ...
    Regardless of PR code for brakes M6x16 is remark with P/N: N 106 483 01 , description is hex socket countersunk bolt ...
  3. Re: Brake disc retaining screw size
    mjhamilton Guest
    then my gut was right again
    Cheer - ordered
  4. Re: Brake disc retaining screw size
    Dec 2009
    Waterlooville U.K.
    13 Post(s)
    If you can find Torx drive C'sk screws they will not round out like hex drive screws.
    Skoda Octavia II SE 1.9PD TDI
  5. Re: Brake disc retaining screw size
    mjhamilton Guest
    Reordered
  6. Re: Brake disc retaining screw size
    Sep 2011
    Quote Originally Posted by gupsterg View Post
    Quote Originally Posted by vwcabriolet1971 View Post
    Quote Originally Posted by mjhamilton View Post
    Reordered
    They are Torx Link:- Genuine VW / Audi BRAKE DISC SCREW (N-106-483-01 / N10648301)
    Blinky VAG catalogue always describes them as hex ...
  1. Question A4 brake disc size
    By HAWKS in forum Audi A4 - B5 Forum - 1995 - 2002
    Last Post: 26-05-2013, 09:06 PM
  2. Question Brake disc size
    By graym78 in forum Passat - B5 Forum - 1997 -2005
    Last Post: 19-01-2010, 01:46 PM
  3. Brake Disc Size
    By Noddi in forum Alhambra
    Last Post: 22-07-2009, 10:20 PM
  4. A4 brake disc size
    By a4_jim in forum Audi A4 - B6 Forum - 2002 - 2005
    Last Post: 16-07-2008, 06:57 PM
  5. Brake disc size for 1.9Tdi SE
    By bayside blue in forum Audi A4 - B5 Forum - 1995 - 2002
    Last Post: 14-02-2008, 02:15 PM
