Thread: Camera stopped working
Results 1 to 10 of 12
  1. Camera stopped working
    May 2009
    Torquay
    I've had the car since new and intermittently over the last four years the rear view camera has stopped working. It pops out but there is only a blue screen on the display. The next time I used reverse however the camera always started working again and I had no further problems for months. Now the situation seems to be permanent. Just a blue screen at all times. Any ideas? Golf GT 160
  2. Re: Camera stopped working
    46 Post(s)
    First of all you need a fault code scan to see if the camera is actually at fault (which I'm guessing it is).
    Since you've had the car from new, I would maybe try a goodwill gesture from VW if you have full VW SH? Can't do any harm asking.
  3. Re: Camera stopped working
    Sep 2009
    Stoke on Trent, England
    12 Post(s)
    As Chris says get your motor scanned for any error codes there are 3 that I know of.
    The rear camera on a mk6 Golf does suffer with a bad water drain. Install drainage for the Golf Mark VI Rear View Camera (RVC) installed in a Golf Mark VI
    2010 Golf GTD (170) CBBB, 5 Door, Shadow Blue (P6/D5Q), Flat Tyre Indicator, Basic Protection Pack + VCDS.
  4. Re: Camera stopped working
    May 2009
    Torquay
    Result 2 hours labour and new camera fitted. £384.
  5. Re: Camera stopped working
    46 Post(s)
    Did you not try for any goodwill?
  6. Re: Camera stopped working
    May 2009
    Torquay
    Not really. Wish I had. I did mention that it was an intermittent fault during the warranty period that I should of mentioned but got no response.
  7. Re: Camera stopped working
    May 2007
    17 Post(s)
    Quite a common fault this one. The camera popping in and out all the time causes the wires to break.
    They always seem to break flush with the camera body, so no way to reconnect it.
    Jim.
  8. Re: Camera stopped working
    Otley West Yorks
    Quote Originally Posted by Flash2 View Post
    Jim.
    Thank for info and picture will keep a eye out on mine for any problems before warranty over I understand what you mean about the camera popping up every time you use reverse they should be some way of switching it of and then put on if you need it.
    Ex Golf Match Now New Leon 1.4 SE SC
  9. Re: Camera stopped working
    Sep 2009
    12 Post(s)
    Reversing camera - 5K0 980 551 - £201.78
  10. Re: Camera stopped working
    Otley West Yorks
    Quote Originally Posted by Keithuk View Post
    It would be cheaper to pay somebody to sit in the back and look out out!!!
  1. Bluetooth stopped working
    By fantum farter in forum Audi A6 - C6 Forum - 2005 - 2010
    Last Post: 04-04-2012, 11:16 PM
  2. Reversing camera not working?
    By yuppyflyer in forum Passat - B7 Forum - 2011 - 2015
    Last Post: 23-09-2011, 12:50 PM
  3. Parking sensors and rear view camera stopped working
    By Eddo1968 in forum Audi A4 - B8 Forum - 2008 - 2015
    Last Post: 30-05-2010, 06:36 PM
  4. Please Help Heater has stopped working
    By xXBADGERXx in forum Golf MK3 - 1993 - 1999
    Last Post: 19-12-2009, 11:22 PM
  5. tv has stopped working
    By audi_130bhp in forum A8 - S8 - V8
    Last Post: 12-12-2009, 09:45 PM
