Thread: Wich vcds to buy for personal use?
Results 1 to 10 of 18
  1. Wich vcds to buy for personal use?
    Mar 2013
    norfolk
    Hi all, as above wich version of vcds to buy? because there are so many out there. dont want to spend more than 100£ if posible..And will it work with win8? if somebody can post link here that would be great..Thanks for all help in advance..
  2. Re: Wich vcds to buy for personal use?
    Aug 2011
    Meath
  3. Re: Wich vcds to buy for personal use?
    46 Post(s)
    For the B6 you could use vcds lite with this cable from gendan - http://www.gendan.co.uk/product_VAGUSB.html
    You can then activate it for $99 and gain some more features from this page
    Ross-Tech: VCDS-Lite
    1 1 0
  4. Re: Wich vcds to buy for personal use?
    Mar 2013
    norfolk
    Do you know if vcds lite will work with win8 ?
  5. Re: Wich vcds to buy for personal use?
    46 Post(s)
    From - Ross-Tech: FAQ Page 1
    1.15 Will VCDS work on Windows 8?
    Yes, all current versions of VCDS and VCDS-Lite are fully compatible with Windows 8. If you're using an old version that isn't, please update.
    If you feel you're ready for the full fat vcds then go with the one Doc posted but start learning with vcds-lite first if you haven't used it and want to try it out before spending £200+.
  6. Re: Wich vcds to buy for personal use?
    Mar 2013
    norfolk
    thanks for your help.
  7. Re: Wich vcds to buy for personal use?
    mjhamilton Guest
    Vcds-lite and a cheap eBay cable has been good to me thus far
    It's the really complex stuff and firmware upgrades that it cannot do but these are things that come up once in a lifetime and are things that are normally out side the capabilities of the home mechanic
    Just my 2 pence on this one for what it's worth
  8. Re: Wich vcds to buy for personal use?
    Aug 2011
    Meath
    I'm a home mechanic
    Quote Originally Posted by mjhamilton View Post
  9. Re: Wich vcds to buy for personal use?
    mjhamilton Guest
    my post was aimed at the Op
  10. Re: Wich vcds to buy for personal use?
    Aug 2011
    Meath
    LOL I wept all night
  1. Why should I buy VCDS?
    By darich in forum Audi A4 - B7 Forum - 2005 - 2008
    Last Post: 06-03-2012, 11:38 PM
  2. VCDS Release 11.11 and which cable do I need to buy
    By tonyandkaty in forum VCDS - General Questions
    Last Post: 22-12-2011, 07:41 PM
  3. Should I buy VCDS?
    By Phil_P in forum VCDS - General Questions
    Last Post: 05-10-2010, 09:21 PM
  4. wich cordoba?
    By rusthater in forum Ibiza - Cordoba
    Last Post: 04-08-2008, 11:00 PM
