Thread: 1999 A4 AHU 1.9TDI dual mass or single mass flywheel?
Results 1 to 10 of 14
  1. 1999 A4 AHU 1.9TDI dual mass or single mass flywheel?
    Dec 2007
    My April 1999 1.9TDI AHU engined A4 is going to need a new clutch sharpish. Anyone know if its single or dual mass flywheel? Can't remember if it's a 90 or 115 bhp....
  2. Re: 1999 A4 AHU 1.9TDI dual mass or single mass flywheel?
    46 Post(s)
    According to this thread - 1.9 tdi ahu dual mass?
    It's single mass but check first.
    BUT this thread Crasher states it has a DMF
    https://www.vwaudiforum.co.uk/forum/s...have-i-got-one
  3. Re: 1999 A4 AHU 1.9TDI dual mass or single mass flywheel?
    Dec 2007
    Thanks for the links. I've ended up calling Audi parts and they think, based on the engine code, that it's highly likely to have a DMF. Bugger. Reckon I'll use GSF for parts when needed, unless someone else has a good link for parts?
  4. Re: 1999 A4 AHU 1.9TDI dual mass or single mass flywheel?
    Pembrokeshire
    22 Post(s)
    its a 90 bhp rotary pump is an ahu. as to whether or not it has a dmf is anyones guess. i would say no it doesn't but if you call a reputable factors and give them the reg then they should be able to look it up and say for certain. i know mine can and they have never been wrong.
  5. Re: 1999 A4 AHU 1.9TDI dual mass or single mass flywheel?
    Aug 2011
    Meath
    I think it is SMF on the older A4's I assume it depends on what vehicle the engine is fitted to. GSF and Europarts have an option to search by reg number
  6. Re: 1999 A4 AHU 1.9TDI dual mass or single mass flywheel?
    Aug 2011
    Meath
  7. Re: 1999 A4 AHU 1.9TDI dual mass or single mass flywheel?
    Pembrokeshire
    22 Post(s)
    ooh, i wouldn't fit a sachs clutch. from what i can work out my audi had never had a new clutch at 310k miles and that was an original sachs that was fitted. mind you, i don't suppose 310k is too bad, especially when the po towed a caravan with it.
    1 1 0
  8. Re: 1999 A4 AHU 1.9TDI dual mass or single mass flywheel?
    Aug 2011
    Meath
    Cheap badly made crap Z !
    1 1 0
  9. Re: 1999 A4 AHU 1.9TDI dual mass or single mass flywheel?
    Jul 2010
    Waterford Ireland
    I've the same car and I've always wondered if it has an SMF. suppose the fact that it hasnt failed yet is a good indicator (I had 2 go on my 407 )
    2006 VW Sharan 1.9 TDi 90 Bhp ANU Engine
  10. Re: 1999 A4 AHU 1.9TDI dual mass or single mass flywheel?
    Aug 2011
    Meath
    Yo Dredd how did the event go?
    Quote Originally Posted by dreddfan View Post
  1. Replace Dual Mass with single mass? TDI 105
    By andwat in forum Golf MK5 - 2004 - 2009
    Last Post: 18-10-2023, 08:44 PM
  2. Question Flywheel - Dual Mass or Single 99 Passat?
    By audicab26 in forum Passat - B5 Forum - 1997 -2005
    Last Post: 19-05-2013, 12:14 AM
  3. Any B5 1.9tdi WITHOUT dual mass flywheel?
    By Arrrr Jimlad in forum Audi A4 - B5 Forum - 1995 - 2002
    Last Post: 05-03-2012, 03:41 PM
  4. 1.9 tdi ahu dual mass?
    By gregomega in forum Audi A4 - B5 Forum - 1995 - 2002
    Last Post: 04-07-2010, 09:31 AM
  5. Please Help AUDI A3 1.9tdi dual mass flywheel problem??
    By sharp15 in forum New Member Introductions
    Last Post: 04-12-2009, 12:50 PM
