Thread: Poor FM & DAB reception
Results 1 to 10 of 46
  1. Poor FM & DAB reception
    Nov 2012
    coalville leicestershire
    Both My FM & DAB reception is lousy.
    Frequently drops DAB & switches back to FM - MMI shows DAB(FM)
    FM reception is hissy and drops the station 20 miles before the wife's Mitsubishi Colt
    No faults recorded by VCDS.
    No wiring problems or corrosion on the connectors.
    I ordered a Kinetic DRA-6001 DAB/DAB+/FM/SW/MW/LW car aerial to see if It will help + cables & Fakra adaptors
    Kinetic DRA-6001 DAB/DABplus/FM/SW/MW/LW Car Radio Aerial Antenna
    Anyone know how to connect this via the diversity amp or direct to the FM & DAB modules
  2. Re: Poor FM & DAB reception
    Nov 2012
    Any ideas on the IF IN connection?
  3. Re: Poor FM & DAB reception
    Sep 2011
    Lurking over a keyboard ...
    FM1
    FM3/4
    I believe are the different aerials located in windows, the others without looking at service guide no idea but will get back to you if no one else give you info ...
    Above is the the side of the K-Box / Tuner facing the bodywork, the black port on far right is the power plug next to it is optical fibre connection the rest I will look up and update info ...
    Does the aerial you have bought have a separate DAB and RF fakra? why I ask as tuner and dab modules have separate aerial fakras ...
    DAB does not use the AMP you have photographed ...
  4. Re: Poor FM & DAB reception
    Nov 2012
    Thanks Gup
    The DRA-6001 aerial has separate DAB & FM connections
    I will connect the DAB direct to the DAB module & try the FM to one of the DivAmp FM inputs
    In your photo are there 2 Fakra connectors?
    Richard
  5. Re: Poor FM & DAB reception
    Nov 2012
    Fitted, so I'll see if there is an improvement on the way to work tomorrow.
    I there a way to see the signal strength & quality/error rate on the DAB?
  6. Poor FM & DAB reception
    Nov 2009
    46 Post(s)
    Yes go into your hidden menu (hold in car + setup) but you'll need this activated by vcds if it isn't already
    Hidden menu -> Tuner -> DAB Tuner Quality
    should be looking at the Qual value.
  1. DAB Aerial/Reception
    By apole in forum Audi A6 - C6 Forum - 2005 - 2010
    Last Post: 15-06-2013, 01:55 PM
  2. dab reception
    By bhprs in forum Audi A4 - B8 Forum - 2008 - 2015
    Last Post: 04-11-2010, 01:49 PM
  3. Replies: 2
    Last Post: 24-10-2009, 11:18 PM
  4. POOR RECEPTION
    By new to vw in forum Passat - Archive Topics
    Last Post: 19-12-2007, 10:46 AM
