Thread: Radio upgrade in 2008 passat
Results 1 to 10 of 11
  1. Radio upgrade in 2008 passat
    Aug 2013
    Diss Norfolk
    Hi would like to upgrade the stereo in my 2008 passat to a DAB unit, will the rds310 or rds510 unit fit in without any additional parts? And is it a easy job to do?
    many thanks
    jamied-80
  2. Re: Radio upgrade in 2008 passat
    Mar 2009
    York
    What stereo do you have at the moment? If its an rcd310 its a straight swap but with the extra hassle of routing to a dab aerial, which if your serious should at least be a windscreen mounted external type.
    Only thing in not sure about because of the different LCD colour is how it will interact with your red-dot MFD (if you have highline) as these units were made to pair up with the white-dot colour MFD from 2009 onwards...
    Sent from my iPhone using Tapatalk - now Free
    A3 8V S-Line Cabriolet 2.0 TDI
    Passat B6 FSI • Passat TDI 105 • BMW E90 318d • BMW F30 320d Lux
  3. Re: Radio upgrade in 2008 passat
    Aug 2013
    Diss Norfolk
    Quote Originally Posted by patomlin76 View Post
    Thanks for your reply. I have heard others say that the battery will drain on certain cars, do you know if this will affect mine?
  4. Re: Radio upgrade in 2008 passat
    Mar 2009
    York
    If you have an rcd 310 it definitely won't. If you've got an rcd300/500 then it may, but if you ask the dealer they will be able to tell you for certain whether you have the upgraded can bus gateway
  5. Re: Radio upgrade in 2008 passat
    Sep 2008
    SE London
    Got a help .doc file here which I collected with all the front panel pix and options' stuff. PM me an e-mail address and I can send it
  6. Re: Radio upgrade in 2008 passat
    Aug 2013
    Evesham
    Quote Originally Posted by RichardSEL View Post
    Hi Richard, I've too few posts to PM you also, (I'm upgrading to an RCD 510 soon and am just about to fit a red dot matrix MFD also.. so I'd love a copy also of your help .doc file if that's ok?
    Jon
  7. Re: Radio upgrade in 2008 passat
    Sep 2008
    SE London
    Dunno about your CANbus gateway as your's is a 2008MY, generally a "F" and onward is alright and doesn't give battery drain issues with an RCD510 You can see what gateway you've got by:
    removing your Climatronic knobs, the existing radio's surround (remove bulb holder from surround without removing the connector if the surround gets in your way), remove Climatronic unit (four T25 screws) and remove the three plugs.
    If you've got Climatic there's a Bowden cable there that's difficult to remove and replace correctly so better that not be disconnected
    Behind the Climatic or Climatronic unit is the CANbus gateway held in place by two bolts and a bar across. The bolts need only be loosened. If you've got slim wrists reach in and lift out the module. Untwist the module's cable without removing plug if posssible and you should be able to see a 3c0 number ending in a letter. Mine's a "C" so can't upgrade to RCD or RNS510 without an upgraded module.
    Easier though is to get someone with VCDS to do an Autoscan. You'd then get:
    Address 19: CAN Gateway Labels: 3C0-907-530-V1.clb
    Part No SW: 3C0 907 530 C HW: 3C0 907 951 A
    CANbus gateway rev: ^^^
    Component: Gateway 007 0040
    Revision: 00007000 Serial number: 0700C0621500F6
    Coding: 3FFD0C04C22003
    Shop #: WSC 05311 123 12345
    VCID: 21672875F8755316A2B
    Can't post help file here or by Fileattach in a PM to you as it's 2.8MB. Not gonna post my e-mail address in open forum as that's an invitation to spam bots, identity theft, etc.
    I got Hazzy Dayz to do my steering wheel upgrade to MFSW together with red hi-line MFD. Needed upgraded steering wheel controller and small loom (dual stage airbags here) for this. Kit fitted in my sig doesn't show Navi next turn, track info, or phonebook in MFD but with Connects2 interface get "Audio" menu which gives me MFSW control of the headunit. And voice dialling with a compatible 'phone.
    Perhaps our moderator extrordinaire in here will adjust your PM status so as to allow you to PM me?
    Anyways, with the other replies you've got hope that helps?
  8. Re: Radio upgrade in 2008 passat
    46 Post(s)
    Richard, you can PM anybody regardless of their post count.
    If you leave a space or put in some * your email won't be picked up by spam bots
  9. Re: Radio upgrade in 2008 passat
    Sep 2008
    SE London
    Richard, you can PM anybody regardless of their post count. If you leave a space or put in some * your email won't be picked up by spam bots
    Ta!
    Jon928: You have PM
  10. Re: Radio upgrade in 2008 passat
    Aug 2013
    Evesham
    Ta!
    Jon928: You have PM
    Hi Richard, thanks for the info. Did you have to change the central convenience module when you fitted the MFD & MFSW, (I had the chance of getting that too - but didn't...)?
    Regards
    Jom
    P.S Where are you guys located, could do with my mileage resetting to match car, (when I get around to fitting it) - looking for someone that could do that??
  1. Poor radio reception 2008 passat all original equipment
    By PASSAT57D in forum Passat - B6 Forum - 2005 - 2010
    Last Post: 12-02-2012, 07:56 PM
  2. Audi A3 1.9tdi 2008 CHORUS Head-Unit Upgrade
    By sum-vwaudi in forum In Car Entertainment
    Last Post: 11-07-2011, 07:51 PM
  3. Question Can you upgrade the Radio to Newer VAG Radio
    By ChillOut in forum Passat - B5 Forum - 1997 -2005
    Last Post: 22-04-2010, 03:21 PM
  4. Passat 2008 (08) radio/CD & owners handbook
    By cj21575 in forum Passat - B6 Forum - 2005 - 2010
    Last Post: 27-10-2009, 01:31 PM
  5. Question 2004 Symphony II - 2008 Concert upgrade...
    By randall977 in forum In Car Entertainment
    Last Post: 26-08-2008, 10:40 AM
