Thread: knocking
Results 1 to 10 of 15
  1. knocking
    Jun 2006
    Is there anything common which can cause knocking over bumps at low speed ie bushes/shocks/top balljoints/ wishbones
    Feb 2004
    Yorkshire
    49 Post(s)
    The front suspension on 98- Passats has 4 wishobones, and an anti roll bar link on each side. These are a very common area for failure.
    From what you say, I would imagine one of these wishbones/links are worn.
    Stuart
    Stuart l VWAudi Forum
    VW Audi Forum - Founder
    Ways to support the website
    Jun 2006
    cheers what i thought
    Jul 2006
    Recently done my 4 lowers as they were creaking. Now got knocking on O/S. Guess it might be the upper suspension arms now The list of jobs is endless!
    Jun 2006
    complicated front susp set up on a passat prone to wear
    Jul 2006
    Aye
    Nice car but I'd kinda like my weekends back
    Jan 2006
    Nottingham
    Welcome to the world of passat ownership!
    Jul 2006
    so far this year
    new rear discs and pads
    new viscous fan unit
    4 new lower suspension arms
    new oil pump
    new clutch
    lots of smaller jobs
    These jobs suck when you're on your drive in winter. It's cold and gets dark by 4pm!
    Still got a bunch more including
    a bad boost leak that I can't find
    The above mentioned knocking
    a petrol smell after turning the car off
    A slack gearbox
    others
    what fun
    Jan 2006
    Nottingham
    Have you replaced all the seals to try and cure the boost leak?
    The passat boost pipes are the worst I have seen on a turbo car, particularly one that blows up to 30 psi!
    I have the same problem cant find mine either!
    Jul 2006
    So far I've had the lock carrier off twice to check all obvious hoses (had all larger hoses off individually but I'm struggling to find anywhere other than VW who stock the clips for the small vacuum lines so haven't actually pulled all those off apart from the two coming from the intake manifold which I have replaced as they were a bit ropey. I have also invested in a new diverter valve. I could replace the whole system but that would be crazy and can't afford to buy another item that doesn't actually need replacing.
    Someone has mentioned it could be the actuator on the turbo sticking. Not sure how that would give me the sound of a leak but I guess air has to go somewhere.
    What exactly do you mean by 'seals'?
    cheers
  1. 05 Polo 130 GT TDI knocking
    By Busflyer in forum Golf - Jetta - Vento - Bora - Archive Topics
    Last Post: 19-11-2007, 05:20 PM
  2. Suspension knocking!!!
    By SRA4 in forum Audi A4 - B5 Forum - 1995 - 2002
    Last Post: 10-06-2007, 09:11 PM
  3. Steering Knocking
    By MikeA4tdi in forum Audi A4 - B5 Forum - 1995 - 2002
    Last Post: 09-05-2007, 09:38 AM
  4. Knocking when idling?
    By MarkMk3 in forum Golf - Jetta - Vento - Bora - Archive Topics
    Last Post: 21-02-2007, 12:39 PM
  5. Knocking Wheel
    By The Sloth in forum Golf MK2 - 1984 - 1992
    Last Post: 15-09-2006, 08:34 PM
