Thread: RCD 310 - fitting a CD changer
  1. RCD 310 - fitting a CD changer
    Jul 2013
    Wales
    I have a 2010 1.6 tdi se There is an usb connection in the arm rest, along with a slot for a cd changer? Is this where the cd canger fits? Will an arm rest cd changer from a mk5 fit this car, or if not what will?
  2. Re: RCD 310 - fitting a CD changer
    Scunthorpe
    I can't offer a solution but why a CD changer?
    Don't the newer stereos have the cd changer built in to the HU though?
  3. Re: RCD 310 - fitting a CD changer
    Jan 2010
    uk
    Not sure about the cd changer but it sounds as though you have the MDI unit fitted. The car should have come with 2 leads, 1 an MDI to ipod lead & also the MDI to socket USB connection lead. Instead of using a limited number of CDs you could use a large memory stick or even a 2.5inch USB hard drive. I have the same setup with RCD310 and MDI and use a USB powered 500GB hard drive formatted to FAT32. There is the the space to put about 5000 albums on there. Much easier than fitting a cd changer as a hard drive will only cost about £50 and all you need do is convert yr cds to mp3 and put each album in a folder with a name and copy to the drive.
    Golf mk6 (2010) 1.6S TDI (105) 5 Door Shadow Blue
    Alloys, Sunroof, Fogs, 310 Radio+MDI, Highline, Mats, Service Plan, GAP+Smart Repair.
  4. Re: RCD 310 - fitting a CD changer
    Sep 2009
    Stoke on Trent, England
    12 Post(s)
    Welcome to the forum.
    I see you've asked the same question on another forum I use so I will post the same answer.
    Well the pin configuration says so Volkswagen RCD 310 pin assignments even though it says 5. Multi-pin connector 4, 12-pin, for CD changer control and CD audio input signals it doesn't show 5.
    Overview of connectors on radio RCD 310
    Again you can add your car spec to your signature as it saves users asking.
    2010 Golf GTD (170) CBBB, 5 Door, Shadow Blue (P6/D5Q), Flat Tyre Indicator, Basic Protection Pack + VCDS.
  5. Re: RCD 310 - fitting a CD changer
    May 2012
    Melbourne, Australia
    Quote Originally Posted by lucid View Post
    The sound quality from a CD will beat MP3 anyday.
    Just depends whether 'jodanuke' is an audiophile or not, and how good the factory amp and speakers are.
    Does the RCD accept .wav files? Whilst not quite up to FLAC compression, .wav does give near CD quality sound.
    ...One of these days people and manufacturers will wake up to FLAC (even OGG would do) and stop using MP3/AAC, but that's for another thread...
    2001 Audi S8 - Solar sunroof, heated front and rear seats (just what you need in Australia!), tint, RNS-D, XCarlink, Bose, clunky old phone in arm rest! 1997 Audi A4Q - Hamilton's Club Sport, 5sp man, full leather, sunroof, ASA AR1 17's, Clarion with 12 stacker in boot. 1986 Holden Calais - Velour, 5.0 V8 (Holden 304), Trimatic, Simmons F90 16's, project car (well, 6 years ago...)
  6. Re: RCD 310 - fitting a CD changer
    May 2008
    London, UK
    another idea would be to upgrade to the rcd510 which has a built in 6-cd changer, also adding an SD card reader and large colour touchscreen. it's a straight swap, very easy to fit and can be had of eBay for under £200
  7. Re: RCD 310 - fitting a CD changer
    Jan 2010
    uk
    I use both and encode all my audio to LAME MP3 320kb/s. In reality it is nigh on impossible to tell whether it is CD or high quality mp3 at that data rate in the car. Granted if you use higher compression and lower data rates you have a point.
    Checking the instruction book re the RCD310 with MDI reveals that supported formats are: MP3 (48-320KB/s), WMA, OGG Vorbis & AAC
  1. RCD-310 to RCD-510 upgrade
    By shinysheff in forum Tiguan
    Last Post: 28-09-2011, 10:49 AM
  2. Please Help RCD 300 to RCD 310
    By JOEGOLFPLUS in forum In Car Entertainment
    Last Post: 14-03-2011, 09:11 PM
  3. RCD 310 code
    By tz_tz in forum Golf MK6 - 2009 - 2013
    Last Post: 18-05-2010, 06:16 PM
  4. rcd 310 user guide
    By steve.p54 in forum In Car Entertainment
    Last Post: 05-03-2010, 06:05 PM
  5. Rcd 310 to rcd 510 please help
    By veritas200700 in forum In Car Entertainment
    Last Post: 21-07-2009, 10:18 PM
