Thread: Clunk from front right wheel arch when pulling off to the right
  1. Clunk from front right wheel arch when pulling off to the right
    Jun 2012
    Peterborough, UK
    At the moment I have to pull away quite hard to get it to happen and it must be while I've got a reasonable amount of right lock on. It's like someone tapping the bulkhead semi hard with a small hammer, just near your right foot. You only get a single tap so not CV joint I think.
    My gut feeling is that it's a loose bolt or something like that. Any ideas?
    Passat 2.0 TDI Sport 5dr Estate (170PS) 3C5 M6F CBBB (Sold 08/04/2019)
    Polo 1.2 TSI 77 kW (105PS) A05 6R1 4F2 (Mk5) M6F CBZB
    If you post for help please close the loop and post how you finally solved the problem.
  2. Re: Clunk from front right wheel arch when pulling off to the right
    Pembrokeshire
    22 Post(s)
    possibly a loose bolt, more likely a worn bush , arb link or still could be the cv.
  3. Re: Clunk from front right wheel arch when pulling off to the right
    DSG4ME Guest
    Check the kerbside inner one, boot splits real easy.
  4. Re: Clunk from front right wheel arch when pulling off to the right
    Norfolk
    It might be a sticking pad in the front caliper. You need to have a look.
  5. Re: Clunk from front right wheel arch when pulling off to the right
    DSG4ME Guest
    To give you a list
    Link bar
    CVJ
    Strut Mount
    Loose wheel nut
    Bottom swivel
    Bottom arm bushes
    Pad play
    Engine or box mount *this is classic if the bulkhead is drumming* it's the torque sends the lump back and it hits.
    Whats your stationary steering like, is it groaning or not?
  6. Re: Clunk from front right wheel arch when pulling off to the right
    Jun 2012
    Peterborough, UK
    I went into a roundabout a little spirited with the clutch in and I can get the clunk, I suspect a subframe bolt more than ever now. I think it's getting worse too so I may be able to get it to move with a bar at some point. Or nurse it to the MOT (December I think) and see if they find anything.
  7. Re: Clunk from front right wheel arch when pulling off to the right
    DSG4ME Guest
    Quote Originally Posted by MHDxMK5BK View Post
    Hmmmm, that rules out engine mounts,
    Now I've another test for you,
    Drive up to a junction or anywhere you can safely do 40 mph and stop abruptly,
    Once you are stopped or nearly stopped feel for what I can only describe as the engine traveling on on it's own as if it was leaving the car through the front grille,
    If you are getting this I think it could be your DMF is on it's way out and running unbalanced, I'm assuming that is what causes this phenomenon anyway.
  8. Re: Clunk from front right wheel arch when pulling off to the right
    Jun 2012
    Peterborough, UK
    Knock hasn't happened for quite a while and it passed the MOT the other day with no advisories so this will remain a mystery until it resurfaces.
  1. Replies: 1
    Last Post: 04-01-2013, 01:56 PM
  2. Question Front wheel arch liners
    By danclyon in forum Audi A4 - B6 Forum - 2002 - 2005
    Last Post: 19-06-2012, 08:29 PM
  3. front wheel arch liners
    By jakerade in forum Audi A4 - B8 Forum - 2008 - 2015
    Last Post: 14-02-2009, 06:57 PM
  4. water coming from the front wheel arch
    By nerrad in forum Passat - B5 Forum - 1997 -2005
    Last Post: 23-07-2007, 11:13 PM
  5. mk4 golf front clunk on full lock then front rattle over bumps
    By jwexqm in forum Golf MK4 - 1999 - 2004
    Last Post: 30-05-2007, 11:04 PM
