Thread: W reg allroad self leveling issue ?
Results 1 to 8 of 8
  1. W reg allroad self leveling issue ?
    london/ UK
    Good morning chaps, i have a small issue with my allroad, basically the 10A fuse in the side fuse panel keeps blowing and the car is not self leveling anymore. The bags does not loose air and when i plug in a new 10A fuse the compressor kick in as it should and the car lifts/lowers as it should. I had a few months ago the 40A fuse blow due to lifting the back when replacing both tyres at the back, both fuses blown then, replaced them and the suspension been ok till now ! Any ideas ? Thanks !
  2. Re: W reg allroad self leveling issue ?
    Ayrshire, Scotland
    18 Post(s)
    according to the diagram there are 3 X 10 amp fuses, fuses: S5, S7 & S17 can you tell what one it is blowing?, one is for the ECU one for the up/down switches and one for ESP (going by the diagram anyway. I can mail to you if you don't have it, its to large to attach here, PM me your e-mail)
    Not that I have a solution for you, but it may point to an area to look for a potential issue, any error codes?
    Regards
    Andy
    2001 Audi A4 Saloon 2.0
    2000 Audi Allroad 2.5TDI V6 quattro
    Fully licenced Ross-Tech VCDS Interface
    Air Suspension Compressor Repair Kits: www.bagpipingandy.com
  3. Re: W reg allroad self leveling issue ?
    london/ UK
    Thanks Andy, the one that blows is the 2nd fuse down on 2nd row of fuses from left to right ! It also supplies power to the parking sensors as they don't work anymore when the fuse blows ! No faults last time i've checked but i will scan it again tomorrow ! Thanks for your help...
  4. Re: W reg allroad self leveling issue ?
    Ayrshire, Scotland
    18 Post(s)
    I think that is position S17, powers the ECU I think, which on mine it suggest navigation also, so worth a look at check parking sensor module and radio for error codes too? it may be one of these units rather than the suspension at fault, worth a look
    regards
    Andy
  5. Re: W reg allroad self leveling issue ?
    london/ UK
    Hi Andy, it's funny you mentioned the parking sensors, i had them working on or off and no issues with the suspension, also fitted a factory satnav as well and that works well too (done it after the problem started !), however i have a fault on front/rear leveling sensors, they seem to trigger the fuse to blow ! If i put a new fuse the suspension works just fine for a while, however there seems to be something shorting there if it keeps blowing the fuse ! Just the right timing, i have a friend who offered me good money for the allroad but with the condition i sell it with all the mods which cost me like a few grand !
  6. Re: W reg allroad self leveling issue ?
    Sep 2009
    A406
    You will probably end up looking after the car after he buys it anyway, so will have get to the bottom of this issue sooner or later.
    All the extras you put in the car over years never add to value when you sell.
    V6 Tdi Power!
  7. Re: W reg allroad self leveling issue ?
    london/ UK
    Just an update: the chap that wanted the car changed his mind so it did me a big favor as i would not feel happy getting rid with all the mods on it. Since that i have been using the car every so often, sold the AFB injectors fitted with Bosio power plus nozzles and the gt2056 hybrid then made another gt2260 and got some race nozzles + a 4 Bar map sensor. Looking back i wish i stuck with the pp683 nozzles, the allroad has a 3 plunger pump so can push a lot of fuel, with the larger turbo and nozzles i got a bit of smoke under 2000rpm's + the clutch is complaining too ! On the plus side, the suspension is back working fine but the compressor is a bit noisy and requires a rebuild- i have Andy's kit just lack time to fit !
    Last upgrades are rns e sat nav and a mint rs6+ interior with matching door cards- transformed the way old girl looks and feels on long trips. Also aquired a pair of BDG heads from a hydrolocked engine so i will start porting them very soon. I also have my eyes on a set of arnots gen2 airbags, not that i want the car to be any bumpier but i would love to tighten the back end a touch more. I will use new genuine rear shocks at the same time, however i am still thinking to sell the engine and start from scratch. Next on the cards is new clutch and flywheel...
  8. Re: W reg allroad self leveling issue ?
    Ayrshire, Scotland
    18 Post(s)
    when i 1st read your post i was surprised when you mentioned to sell it as you have done a load of big mods, good to hear its staying!! hopefully it will behave itself for a while yet!!!
    regards
    Andy
  1. Please Help VW Crafter 08 Reg Starting Issue
    By HelpwithCrafter in forum The Commercial Range
    Last Post: 11-06-2015, 08:56 PM
  2. Please Help A4 TDI Help please (V REG) - 2 issue
    By Connor_Scotland in forum Audi A4 - B5 Forum - 1995 - 2002
    Last Post: 13-12-2010, 07:39 PM
  3. A6 Allroad 2.7T sparkplug issue
    By slickoneuk in forum Audi A6 - C4 Forum - 1994 - 1997
    Last Post: 05-05-2010, 06:22 AM
  4. Allroad 2.5TDI Power Issue
    By francoisd2446 in forum A6 - S6 - RS6 - - Archive Topics
    Last Post: 01-03-2009, 12:09 PM
  5. Central Locking Issue - T reg passat
    By Daz1 in forum Passat - B5 Forum - 1997 -2005
    Last Post: 02-05-2008, 03:03 PM
