Thread: Passat tdi 170 problem
  1. Angry Passat tdi 170 problem
    Apr 2013
    Darlington
    Hey again guys, a short while back i posted about my passat chuffing blue smoke out all the time. I took it back to vw who SAY they changed the injector seals but the problem still occured then told me the dpf was blocked, Any how when i got home i checked the dpf and its been cut out ! and possibly mapped problem is smokes constantly, slight struggle on start up and last but not least new issue is if i keep the revs at a steady 1300-1500 revs in any gear whilst driving the car stutter's and surge but accelerates perfect through the rev range :S any idea's what could be causing this, also the smoke smells like unburnt fuel.... anybody help me with this ? all advice welcomed
  2. Re: Passat tdi 170 problem
    Norfolk
    Quote Originally Posted by l200jmc View Post
    If the dpf has been removed the ecu will have been remapped. This may have been done poorly. You will need a remap expert to read your ecu and tell you. The car may have an engine fault but you can't be sure until the ecu map is checked. What does a code scan tell you?
  3. Re: Passat tdi 170 problem
    Apr 2013
    Darlington
    Hey when i scanned it with the vag com, no engine faults come up, only fault is with the parking sensor :/
  4. Re: Passat tdi 170 problem
    DSG4ME Guest
    Once the dpf is gone you will get smoke, if it's blue I'd say you have a ringy or the turbo seals are gone.
    TIME TO SELL ON DON'T THINK I'M KIDDING THIS CAR IS THE VW JIF
    Attachment 21930
  1. Passat 2.0 tdi 170 white smoke
    By l200jmc in forum Passat - B6 Forum - 2005 - 2010
    Last Post: 02-07-2013, 06:54 AM
  2. Question Passat 170 tdi exhaust tips -
    By bambamjj in forum Passat - B6 Forum - 2005 - 2010
    Last Post: 21-07-2011, 02:25 PM
  3. Lack of power 170 TDI passat
    By vdub2 in forum Passat - B6 Forum - 2005 - 2010
    Last Post: 29-10-2010, 08:43 PM
  4. Please Help Passat TDI 170 SEL 2007
    By LEE scaff in forum Passat - B6 Forum - 2005 - 2010
    Last Post: 05-09-2008, 01:52 PM
  5. Question Passat Highline 140 TDI CR or Golf GT Sport TDi 170
    By Nodders in forum Passat - B6 Forum - 2005 - 2010
    Last Post: 09-07-2008, 07:18 AM
