Thread: Speaker Upgrade
Results 1 to 10 of 18
  1. Speaker Upgrade
    Feb 2013
    Newcastle Upon Tyne
    Hello
    After a little bit of advice...
    I want to upgrade my the sound system in my car as I think nearly all the speakers have started to crackle in my car
    To start with I know the size of the components installed but just wanted to know if I am correct in saying the below?
    The 6.5" components are subwoofers? Or are they just normal speakers which are enclosed to give it that punch of bass?
    The 3" components are just normal mid range speakers? Or would any speakers do (i.e does not necessarily have to be mid range)?
    The 1" components are tweeters?
    I am really happy with the sound level of the audio at the moment so don't think I would need to upgrade the amp but really need to upgrade the speakers... I assume I could fit aftermarket components without having to change the OEM amp? I currently have the 10 speaker set up, non-bose.
    Any advice would be great
    Thanks in advanced
  2. Re: Speaker Upgrade
    Sep 2012
    Whitstable, Kent
    12 Post(s)
    I would also like clarification on the above as i want to upgrade my front speakers before fitting my 2 power amps into the system via the speaker level inputs. Gonna post in the Audio section too but if any of you have any recomendations for 120watt + bass speakers and 50watt midbass and tweeters, that would be cool
    57 A6 2.0 tdi 140 SE. Standard except for MMI Basic + and a remap by Expert Tuning, and a want list as long as the equator!
  3. Re: Speaker Upgrade
    Feb 2013
    Newcastle Upon Tyne
    Anyone?
  4. Re: Speaker Upgrade
    46 Post(s)
  5. Re: Speaker Upgrade
    Feb 2013
    Newcastle Upon Tyne
    Hi Chris,
    Thanks for the link . I had a look at the thread earlier and that's where I found all the speaker sizes from, however I don't believe my question is answered in that thread... I was wanting to know what each speakers function is i.e is the two 6.5" speakers in the front doors what acts as the subwoofer? Would I need to by 6.5" subwoofers to fit in the enclosure or would any normal speaker do the same job?
    I'm absolutely clueless with the sound system in this car... in the past I have had everything hooked up via RCA's and by splicing into the speaker signals... this car seems a little bit more fiddly than that?
    Thanks again Chris
  6. Re: Speaker Upgrade
    Nov 2012
    Somerset UK
    A few years back I upgraded all of the speakers in my Jag with Kappa Infinity edge driven MMD's and crossovers, no change to amp
    A total of 11 speakers inc sub mounted in stock place behind rear seats
    Now my car is 17yrs old and at the time my local dealer asked me to sit in and have a listen to mine, then invited me to sit in a new XK with Bowers & Wilkins, we both agreed that my sound was by far the superior.
    Appreciate that in many respects they skimp with speakers hidden in doors etc, in the case of my Jag (due to the age) they were made of coated paper...eeek!
  7. Re: Speaker Upgrade
    Sep 2012
    Whitstable, Kent
    12 Post(s)
    I forgot i posted that thread :B Since then i have discovered both amps have speaker level inputs, so will be wiring them in that way once i have upgraded the speakers and figured out what wires go where as i still have no idea.
    Anyone know the max depth subwoofer that will fit?
    And in answor to A6H**, the 6.5" has to be a Sub, the middle is a mid/bass as i don't believe it is a true 3 way set up and the 1" has to be a tweeter. Am gonna search for some Kappa Infinity's as i know they are good.
    1 1 0
  8. Re: Speaker Upgrade
    Sep 2012
    Whitstable, Kent
    12 Post(s)
    Just been doing some googleing and this would be pretty awesome if they will fit JL Audio 6W3v3 Of course you would need 2 of them though and they are right at the top end of my budget.
  9. Re: Speaker Upgrade
    Nov 2012
    Somerset UK
    Weirdly just googled and saw this
    What size speakers fit a 2005 audi a6? - Yahoo! Answers
    I've non bose, but if I were adding a sub (or subs) to my saloon I'd almost definately put them in the rear shelf as there seem (from memory) to be precut holes on the metal for these, accessed from the boot. Would be adding a seperate mono amp to power these and leave the currents as is or upgrade just the speakers alone.
    Methinks a lot more homework needed though!
  10. Re: Speaker Upgrade
    Sep 2012
    Whitstable, Kent
    12 Post(s)
    Quote Originally Posted by MarkTM View Post
    Awesome, thanks Mark I have an Avant so rear shelf isn't an option. I am still tempted to build an enclosure inside my spare wheeland fit a sub in there, but still confused how i woul wire up the amp for it, presumably the only way would be to tap into the wires for the existing subs in the front doors, but then would have to get a decent and powerfull amp to cope with the signal drop from running 2 speakers from the single output.
    These sound alright Lanzar MAXP64 Max Pro 600W 6.5 inch 4 Ohm Small Enclosure Car Subwoofer:Amazon:Electronics
  1. A4 B7 speaker upgrade?
    By 70325 in forum Audi A4 - B7 Forum - 2005 - 2008
    Last Post: 10-09-2012, 09:17 PM
  2. 97 A4 speaker upgrade
    By CAPTAIN.BIRDSEY in forum In Car Entertainment
    Last Post: 18-02-2009, 05:43 PM
  3. Question Speaker Upgrade
    By Sailorf80 in forum The Commercial Range
    Last Post: 02-06-2008, 03:42 PM
  4. Speaker upgrade
    By fenian672000 in forum Audi A4 - B6 Forum - 2002 - 2005
    Last Post: 22-11-2006, 11:20 AM
  5. speaker upgrade A4
    By StuartTKD in forum Chat - Completely Off Topic
    Last Post: 21-11-2006, 08:39 AM
