Hi all,
Spent the morning having a play with the DTUK Box today thought I'd post my feedback.
As mentioned earlier in this thread, I wanted to try and extract a little more poke from my box, so going through the intructions which were actually more informative than I first thought once you get a little involved I decided to stick with the map it was supplied with, which was Map 1 I think, based on the power/torque curve on the instructions it looked to be a smooth power curve from low in the rev range all the way though. What I did want to do, try the map on zero +1, +2 etc which increases the map variables hopefully giving better power increases. This has to be done gradually according to the instructions, as to sharp a change can result in a rough running engine.
To change the the zero +0 which the box was supplid with you have to remove the device from the car (simple plug will do) and remove x4 star bolts from the rear of the unit, two screws securing the circuit board which allows you to access the circuit board to adjust the settings. Might sound daunting playing with circuit boards but its really quite easy! Now you can get to the board all you do to move from zero +0 to zero +1 is remove a small pin and move it over to the pin next door which is your +1. There are another two pins which will allow you to +2, +3 etc. In all very easy and takes a few minutes.
So... how'd I get on? Well the plus +1 gave a moderate increase so feeling brave I moved straight to zero +2 and WOW made a real difference. The car pulls really well, and give you a nice little shove which with the original 110bhp it was hugely lacking! So far I cant see any tell tail signs that I've been too greedy with my power gains, with no engine management light, no smoke and she does not appear to be running roughly.... hard to tell with an oil burner as they will always sound a bit like a tractor!!
Going to stick with the zero map for a while and see how I get on, as suits my driving, allowing me to change up nice n early to save fuel or have the grunt all over the rev range when I need it. Though I do wonder..... will I get away with a zero +3
So in summary so far my relationship with the DTUK tuning box has been a very good one
