Thread: VW touran Sticky throttle
  1. VW touran Sticky throttle
    Oct 2010
    Inverness
    VW Touran 2004, 1.6FSI petrol.
    When you lift your foot off the throttle, it does not return completely to idle immediately.
    So for instance when changing gear, it sounds like you are dojng a bad gear change with the engine racing during the change.
    In normal driving it slows down okay when you lift off the pedal.
    I thought it might be just a sticky linkage, but on this car it looks like the pedal drives a potentiometer, so "drive by wire"
    Is it possible the potentiometer is sticking, if so where / what to lubricate?
    Or is this a symptom of some electronic gizmo or sensor playing up?
  2. Re: VW touran Sticky throttle
    Pembrokeshire
    22 Post(s)
    plug in diagnostic computer and check operation of clutch switch
  3. Re: VW touran Sticky throttle
    Oct 2010
    Inverness
    I will do next time I'm over at my friendly garage.
    So what does this "clutch switch" do then?
  4. Re: VW touran Sticky throttle
    Pembrokeshire
    22 Post(s)
    it tells the ecu when you have your foot on or off the clutch. if it doesn't know you are pressing the clutch down, it doesn't know you are changine gear so it won't drop the revs.
  5. Re: VW touran Sticky throttle
    Oct 2010
    Inverness
    Doh, but you lift the throttle to drop the revs?
    I'm not trying to do a fancy gear change without lifting off the throttle. So why don't the revs die away completely to idle immediately I lift the throttle regardless of the clutch.
    I take the point about the clutch switch and will get it checked in due course, but I just don't see why it's necessary and why the revs don't drop immediately?
  1. Clean throttle body and perfom Throttle Body Alignment (TBA) - big job?
    By allanmb in forum Audi A4 - B7 Forum - 2005 - 2008
    Last Post: 31-01-2013, 09:50 PM
  2. touran- no response from throttle pedal following gear change.
    By steady eddie in forum Touran - Sharan - Caravelle
    Last Post: 19-05-2010, 08:32 PM
  3. Question Touran Gearbox: sticky out of reverse
    By fredthedog in forum Touran - Sharan - Caravelle
    Last Post: 13-05-2010, 12:27 PM
  4. sticky throttle??
    By wheelywonderful in forum TT - 8N Forum - 1998 - 2006
    Last Post: 04-10-2009, 03:52 PM
  5. Please Help Touran -sticky central locking problem
    By stevenwalker in forum Touran - Sharan - Caravelle
    Last Post: 15-08-2008, 12:16 PM
