Thread: Rear camber at limit of adjustment
  1. Rear camber at limit of adjustment
    Oct 2010
    Suffolk, UK
    I took my A6 to a Hunter alignment garage yesterday and there's a possible issue with the left rear camber. Before adjustment it was reading as -1 deg 18' and after it is reading -1 deg 16' (the right rear for comparison is -1 deg 5'). This is outside the recommended range for it but they said it wasn't by much. The issue is they have reached the limit of adjustment for it and said they would probably need to weld something on to give them more adjustment on the (bolt?).
    While I understand what he's talking about in general, I'm hoping someone here may be sufficiently knowledgeable and/or have specific experience of this to be able to recommend the right solution for the job?
    2013 Mk7 Golf GT 2.0tdi DSG
    2005 A3 Sportback 2.0tdi Sport DSG
    Previous:
    2006 A6 Avant 3.0tdi Quattro Le Mans
    2004 A4 Avant 3.0 (petrol) Quattro Sport
  2. Re: Rear camber at limit of adjustment
    Pembrokeshire
    22 Post(s)
    do you have a specific problem with this wheel that got you to get the car aligned ?
  3. Re: Rear camber at limit of adjustment
    Oct 2010
    Suffolk, UK
    I had noticed a greater wear rate on that wheel so I wasn't surprised when the results came back (I always check the tread depths when I swap my winter/summer wheel and tyre sets). I have also noticed a slight vibration through the car that doesn't come from the steering. My wife kerbed both nearside wheels a while back but I didn't think she'd done them that badly as the marks on the wheels were only slight.
    Although the right rear camber is in the green zone, the arrow position is not that far off getting into the red zone as well and both of the toe settings are on the same side too. I'll plug my scanner in and post a picture when I can move the cat out of the way..
    Previous:
  4. Re: Rear camber at limit of adjustment
    Jul 2013
    76 Post(s)
    Is the eccentric bolt moving the wheel carrier?
    Only 3 things that can effect this -
    1. the eccentric bolt has been damaged (or replaced with normal bolt).
    2. the wheel carrier is damaged.
    3. the Traverse control arm is bent as to shorten the movement distance.
    Google SSP 324.
    Dan
    2 2 0
  5. Re: Rear camber at limit of adjustment
    Oct 2010
    Suffolk, UK
    Thanks Dan, I'll check those out.
    Previous:
  6. Re: Rear camber at limit of adjustment
    Oct 2010
    Suffolk, UK
    Oh and yes, I think it is able to move as they did adjust it up to the limits.
    Previous:
  7. Re: Rear camber at limit of adjustment
    Oct 2010
    Suffolk, UK
    Finally got my scanner working:
    I've also come across this as a possible solution - advice welcome as I have no knowledge or experience of anything like this:
    Eibach Rear Camber Shims - Audi A6 (97-07) | eBay
    Previous:
  1. 4 Wheel alignment/ rear camber adjustment
    By xenon in forum Audi A4 - B7 Forum - 2005 - 2008
    Last Post: 12-08-2012, 04:09 PM
  2. Question Front camber adjustment
    By Rustyfile in forum Audi A4 - B5 Forum - 1995 - 2002
    Last Post: 19-02-2010, 01:30 PM
  3. Question V6 rear wheel camber adjustment ?
    By MediaAssassin in forum Golf MK4 - 1999 - 2004
    Last Post: 22-06-2009, 04:59 PM
  4. Polo s reg Camber adjustment
    By jweir@krafteuro in forum Polo - Derby - Lupo - Fox
    Last Post: 26-10-2008, 12:10 PM
  5. camber adjustment after damper change
    By thelastgizmo in forum Vento - 1994 - 1998
    Last Post: 04-01-2008, 11:38 AM
