Thread: Audi B8 tpms with AS abs module
Results 1 to 10 of 13
  1. Smile Audi B8 tpms with AS abs module
    Jul 2013
    Oldham
    Hi all
    this is just really to let people know that i managed to activate tpms today on my 2008 b8 a4
    it has the AS abs module which states it cant be done but after going through all the programming on VCDS the option came up in my MMI and the option to store current tyre pressure was there, clicked store and all seems ok
    have to run through the 'teach in process' and check it all works ok, but all seems ok so far
    hill hold assist next then
  2. Re: Audi B8 tpms with AS abs module
    46 Post(s)
    Excellent - you might get a rouge warning in 100 miles or so as it learns the rotations of the tyres. Just reset and continue.
    Have you tested it yet?
  3. Re: Audi B8 tpms with AS abs module
    Jul 2013
    Oldham
    not tested yet, going to give it a good run it over the next week then deflate a tyre and see
    how do i 'reset and continue'
    cheers
  4. Re: Audi B8 tpms with AS abs module
    Aug 2012
    Hampshire
    So if I try this and it does not work, is it just a case of undo the changes or can it harm anything?
    2013 A6 2.0TDi S-line
    Fully registered VCDS in Portsmouth & surrounding areas & fault diagnostics/resets on most other makes.
  5. Re: Audi B8 tpms with AS abs module
    46 Post(s)
    Yep only a matter of unticking the tpms and hill hold option boxes if it doesn't accept it.
  6. Re: Audi B8 tpms with AS abs module
    Mar 2013
    Manchester uk
    I tried this a while ago on a 1AS abs module with no success. Had to use vcds as my car only has the basic radio. What module type did your car have fitted?
    Wonder if later modules like mine with stop start MY10 are different
    Sent from my GT-I9100 using Tapatalk 2
  7. Re: Audi B8 tpms with AS abs module
    Jul 2013
    Oldham
    Quote Originally Posted by Magicmcfc View Post
    These are some of the details I can see from looking at the top of the module, think this is the right number,
    8k0614517df / 08020715
  8. Re: Audi B8 tpms with AS abs module
    Mar 2013
    Manchester uk
    Ok thanks will have a look and see what numbers are on my module
  9. Re: Audi B8 tpms with AS abs module
    Jun 2008
    Kent
    Tried at the weekend on my 2013 A4 but no luck....didn't work on my previous B8 either
    Glacier White B8 Black Edition 2.0T Fsi quattro stronic - Advanced Key, Nappa Leather, Electric Folding Mirrors, Interior Light pack
  10. Re: Audi B8 tpms with AS abs module
    Jul 2013
    Oldham
    Quote Originally Posted by Plife View Post
    do you not get the options in the screen to store tyre pressures? Is it greyed out so you can't click on it?
    there are 3 places in vag com to switch it on?
  1. coding replacement ABS module Audi B5
    By DeeJames in forum VCDS - Help Requests
    Last Post: 19-06-2013, 04:14 PM
  2. Replies: 4
    Last Post: 08-05-2012, 01:21 PM
  3. abs module removal, must I remove the whole abs unit?
    By Bobby101 in forum Audi A3 - 8L - 1996 - 2003
    Last Post: 16-11-2010, 11:38 AM
  4. '99 2.8 ABS module symptoms? no rev counter, ABS and oil pressure warning.
    By bubbster in forum A6 - S6 - RS6 - - Archive Topics
    Last Post: 26-03-2009, 05:00 PM
