Thread: Fault codes engine and airbag
  1. Fault codes engine and airbag
    Dec 2011
    Bishops Stortford
    Hi, fairly new to the forum, need some help with couple of fault codes after running fault finder. Fault below:
    17058 - Cylinder 4 Glow Plug Circuit (Q13)
    P0674 - 006 - Electrical Fault - Intermittent - MIL ON
    Freeze Frame:
    Fault Status: 10100001
    Fault Priority: 1
    Fault Frequency: 107
    Reset counter: 81
    Mileage: 149980 km
    Time Indication: 0
    Date: 2000.00.00
    Time: 11:14:08
    Freeze Frame:
    RPM: 1088 /min
    Text: 120 Nm
    Speed: 0.0 km/h
    Text: 0.0 %
    Voltage: 14.13 V
    Bin. Bits: 10110000
    Temperature: 20.0°C
    Readiness: N/A
    Second one is:
    Address 15: Airbags Labels: 3C0-909-605.lbl
    Part No SW: 3C0 909 605 J HW: 3C0 909 605 J
    Component: 05 AIRBAG VW8 029 2521
    Revision: 09029000 Serial number: 003A2PPD42EC
    Coding: 0012341
    Shop #: WSC 05311 000 00000
    VCID: 2D51ED87B4130270BBD
    1 Fault Found:
    01217 - Side Airbag Igniter; Driver Side (N199)
    001 - Upper Limit Exceeded - Intermittent - MIL ON
    I have had a look at other posts and all seem to have injector failures associated with them however this is one on its own so any ideas if it is the glow plug or the harness.
    Regarding the airbag presume this the airbag in the passenger A-Pillar. So probably best to check all wires. Anything I should look out for or check? Wires under seat?
    Help is much appreciated,
    Will
  2. Re: Fault codes engine and airbag
    46 Post(s)
  3. Re: Fault codes engine and airbag
    Dec 2011
    Bishops Stortford
    Thanks Chris.
    I did see those pages on the Ross Tech site.
    Presume the airbag in question is the A-Pillar Airbag. Going to check the connections by taking the trim off. If that doesnt solve it i will look at other options.
    Regarding the glow plug circuit as there are no glow plug faults, and the weather is now warm how can I activate that circuit so I can check the wire using alight bulb tester.
  4. Re: Fault codes engine and airbag
    f33nix Guest
    N199 is the side airbag... in the seat. Not in the pillar.
    1 1 0
  5. Re: Fault codes engine and airbag
    Sep 2011
    Lurking over a keyboard ...
    One of your glow plugs has a fault, probably needs replacing ...
    Second is airbag have you checked measuring blocks in airbag module for reading?
    You may find these files handy to have as an owner, google for:-
    SSP339 Passat 2006
    SSP340 Passat 2006 Electrical System
    Q13 is the cylinder 4 glow plug so could be glow plug/wiring to that one, there was link to TDIClub 101 in the Ross Tech DTC wiki that Chris link?
    Here is that Link:- Glow plugs 101 ***Ver. 2.0*** - TDIClub Forums
    You should be able to make circuit come live by doing a basic output test in module 01 (engine) ...
  1. Airbag Fault codes
    By thetowen in forum Audi A4 - B6 Forum - 2002 - 2005
    Last Post: 16-11-2014, 09:11 PM
  2. Question "Airbag Fault!" No ODB2 fault codes??
    By kipperphill in forum Passat - B6 Forum - 2005 - 2010
    Last Post: 20-02-2013, 11:08 AM
  3. Please Help Airbag Light but no fault codes
    By Chris47 in forum Passat - B5 Forum - 1997 -2005
    Last Post: 08-02-2011, 06:27 PM
  4. Please Help Engine Oil Pressure light, No engine fault codes on VAG COM
    By dfilogik in forum Audi A3 - 8L - 1996 - 2003
    Last Post: 04-06-2010, 08:28 PM
  5. Air bag fault codes: Which airbag do I need to look at?
    By toff in forum Audi A4 - B6 Forum - 2002 - 2005
    Last Post: 28-04-2008, 10:17 PM
