Thread: MAP sensor wiring.
Results 1 to 9 of 9
  1. MAP sensor wiring.
    Jul 2012
    United Kingdom
    I've got a 2006 BKP engined car.
    I've been getting error code 18000 which indicates possible map sensor fault. Changed sensor and car seems fine but I'm also going to change wiring loom to sensor as recommended by Wiki- Ross.
    I've bought new loom but new loom has 4 wires, brown,yellow,purple,black+grey, but old wiring only has 2 wires connected,red,black.
    Has anyone got any ideas if all 4 wires should be connected and if so where they plug on ecu.
    Thanks in advance.
  2. Re: MAP sensor wiring.
    I can not find that engine code. Are you sure. Regards Peter
  3. Re: MAP sensor wiring.
    Jul 2012
    United Kingdom
    Hi Peter.
    It's definately a BKP engine. 2.0 tdi
    Cheers Tom
  4. Re: MAP sensor wiring.
    Jul 2012
    United Kingdom
    Done a bit more research and found out which pins the wires go on but for some reason I've only got two wires on sensor plug. The other two are just loose near the sensor.
  5. Re: MAP sensor wiring.
    Sep 2011
    Lurking over a keyboard ...
    From wiring diagrams I viewed using info 2006 Passat BKP 2.0 tdi there should be four wires as MAP sensor (G31) has intake temp sensor (G42) built in ....
    google for SSP316 2.0-litre Diesel Engine , view page 38 ...
  6. Re: MAP sensor wiring.
    Jul 2012
    United Kingdom
    Thanks for the info.
    Can't understand why only two wires are connected to the sensor.
    Some previous owner has been meddling and original wires have been cut and joined into sensor plug. I'll fit new loom and see what happens. Worried about damaging ecu.
  7. Re: MAP sensor wiring.
    Sep 2011
    Hi mate ...
    Check you inbox for info I sent ...
  8. Re: MAP sensor wiring.
    Jul 2012
    United Kingdom
    I've changed wiring loom today and fingers crossed car is running better than ever. Fitted new loom with four wires instead of what was fitted,only two wires and it looked a right bodge.
    A bit fiddly working on ecu plug but after some expert advice from the forum it made it a lot easier.
    Would like to say a special thanks to Crasher and gupsterg for all the help. I owe you both a beer.
    1 1 0
  9. Re: MAP sensor wiring.
    Sep 2011
    No worries mate glad all is well ...
  1. Question Do I need a MAP Sensor??
    By nattyboy in forum Audi A4 - B6 Forum - 2002 - 2005
    Last Post: 03-10-2011, 06:27 PM
  2. Question 2008 a3 tfsi s line map sensor / thrust sensor location..help
    By leigh76 in forum Chat - Anything with wheels
    Last Post: 22-07-2011, 09:44 PM
  3. Please Help 2008 a3 tfsi s line map sensor / thrust sensor location..help
    By leigh76 in forum Audi Cabrio - Coupe - Quattro's - UR Quattro
    Last Post: 22-07-2011, 07:58 PM
  4. 1.6 FSI MAP Sensor Wiring - Please Help!
    By LeeS in forum Golf MK5 - 2004 - 2009
    Last Post: 11-05-2010, 07:12 AM
  5. Thrust Sensor same as Map Sensor?
    By whistleblower in forum A6 - S6 - RS6 - - Archive Topics
    Last Post: 26-05-2007, 06:03 PM
