Hi all,
I am about to do the fuel filter on my A6 (CAGB common rail engine) the long cylindrical Type one.
My question is do you need to bleed it using VCDS or can you just top it up with diesel and go from there.
The manual gives a 'ran out of fuel operation' so is this just the case of running the ignition for the 2 minutes and cranking over until she fires ok.
Also if i get the car into limp mode whats the code to reset this.
Thanks Dan
