Thread: B8 S-Line saloon 20008 rear light cluster problem
  1. B8 S-Line saloon 20008 rear light cluster problem
    Ardfern
    8 Post(s)
    This evening as I was driving home from work, the bulb failure warning light appeared repeatedlyreferring to each of the bulbs in the rear light cluster on the off side of the boot lid. I assume that this is due to a connection problem. Before I start trying to find the source of the problem, has anyone else had this problem?
  2. Re: B8 S-Line saloon 20008 rear light cluster problem
    46 Post(s)
    Take all the bulbs out and check for corrosion on any of the points.
  3. Re: B8 S-Line saloon 20008 rear light cluster problem
    Ardfern
    8 Post(s)
    Thanks for the suggestion Chris. I'll report what I find.
  4. Re: B8 S-Line saloon 20008 rear light cluster problem
    Jul 2011
    newmarket
    sounds like earth wire to cluster overheated and lost contact. just clean plug. but sometimes bulb holder may need replace
  1. 2008 A6 2.0TDI rear light cluster problem
    By actionman in forum Audi A6 - C6 Forum - 2005 - 2010
    Last Post: 19-05-2013, 09:46 PM
  2. Replies: 7
    Last Post: 11-08-2012, 10:13 AM
  3. Rear knock/clunk - O/S/R (2.0TFSI Non Quattro S-Line Saloon 50k Miles)
    By GarJE in forum Audi A4 - B7 Forum - 2005 - 2008
    Last Post: 05-03-2012, 06:46 PM
  4. Rear light cluster - connection problem?
    By Brycie in forum Audi A6 - C6 Forum - 2005 - 2010
    Last Post: 07-01-2012, 01:26 AM
  5. Rear light cluster problem
    By B6Andy101 in forum Golf MK4 - 1999 - 2004
    Last Post: 20-10-2009, 12:21 PM
