Thread: ipod problems audi music interface
Results 1 to 10 of 17
  1. ipod problems audi music interface
    Jul 2013
    hello all
    I have a 2007 a6 SE which I have owned since new. I have audi music interface along side the 6 disc cd changer and suddenly its stopped working. when the audi music interface is selected, the screen just says initialising device and does not load the ipod, I have tried a usb drive and still the same message.
    also maybe not related but ever since it hasn't worked the radio would stop producing sound for 1 second and then cut back in.
    oh i have mmi 2g and the ipod has been fitted since new
    any advice would be great, looks like a great forum.
    thanks.
  2. Re: ipod problems audi music interface
    Jul 2011
    newmarket
    hi. it sounds like your ami it's packed up. and YES it will affect whole mmi cause they all connected thru optical cables, and if one of them causing problems then whole system is playin up.
  3. Re: ipod problems audi music interface
    Jul 2013
    Hi kamil86,
    do you think I need a new ami unit then and will it sort it?
  4. Re: ipod problems audi music interface
    Jul 2011
    newmarket
    am affraid so. but is expensive. around £250, you can buy a optics bypass tool from audi around £8 and plug it in instead ami and check if radio play ok. to do that make sure mmi is off and ignition is off as well
    2 0 0
  5. Re: ipod problems audi music interface
    Sep 2011
    Lurking over a keyboard ...
    Quote Originally Posted by sciggles View Post
    A poster had the same issue with a new AMI unit, he ran the last released firmware update on unit and it started working ... Link:- Ami
    I'd say worth a try before buying new unit and also get a VCDS scan done before you by a new unit as currently you can't be sure if it is AMI unit at fault and not another MMI module ...
    Besides the auto-scan via VCDS running this test will assess MOST loop and MMI modules Link:- Ross-Tech: VCDS Tour: Optical Bus Diagnostics
    You can ask a forum member to scan your car for beer tokens ... Link:- VWAF User Location Map - VCDS - Google Maps
    As you have low post count you can't PM a member but you can PM the mod team ( A6_Chris , mycarsavw , eshrules ) and one of them can PM the member for you ...
    and Welcome to VWAF! ...
    Quote Originally Posted by kamil86 View Post
    Indeed a good little test without VCDS ...
  6. Re: ipod problems audi music interface
    Jan 2012
    Coding Something
    You could also try unplugging the system for a few minutes & see if it comes back up when all reconnected, seen numerous systems just require a soft reset of this nature before, including ami.
    1 1 0
  7. Re: ipod problems audi music interface
    46 Post(s)
    As above, pull it out and out in a optical loop and see if the radio stops cutting out, if it does then you've found your problem.
    Get someone to scan the car with vcds as Gup has advised, it will give you a better insight into what's going on and feel free to PM me any name you find.
    1 1 0
  8. Re: ipod problems audi music interface
    Jul 2013
    thank you all for your replies
    I have ordered one of these off ebay hopefully its the right one Fiber MOST optic loop AUDI MMI 2G, 3G, 3G+ A4, A5, A6, A7, A8, Q3, Q5,Q7 | eBay
    I have a audi specialist 20 minutes from me so will get them to do a fault readout on the car and I have taken the ipod dock out and took some details of the label if it helps
    I have tried the update gupsterg posted but it still won't recognise the device, I will try and do some 'faffing' like the poster in the AMI thread did and cross my fingers
  9. Re: ipod problems audi music interface
    Jul 2013
    hello again
    I got the car to the audi specialist and ran the test that gupsterg suggested
    everything seems fine, I also tried the mmi loop and the sound stopped cutting out so im definitely guessing I need a new music unit?
    the mechanic tried to go into the ipod and he said something like it wasn't responding and displayed an error message.
    Optical Bus Diagnostic : Standard
    Controller Electrical Optical
    19-CAN Gateway OK OK
    07-Control Head(High/D3)OK OK
    0E-Media Player 1 OK OK
    1E-Media Player 2 OK OK
    77-Telephone OK OK
    47-Sound System OK OK
    56-Radio OK OK
    57-TV-Tuner OK OK
    67-Voice Control OK OK
    37-Navigation OK OK
    0F-Digital Radio(DAB) OK OK
  10. Re: ipod problems audi music interface
    Jan 2012
    Coding Something
    ATM it stands to reason.
  1. Question 2010 A4 with Audi Music interface - A2DP music Bluetooth dongle
    By Pbro in forum Audi A4 - B8 Forum - 2008 - 2015
    Last Post: 01-03-2013, 10:10 PM
  2. Question Audi Music Interface and AAC music files
    Last Post: 07-01-2013, 01:54 AM
  3. Silly question - Audi Music Interface
    By JRW1979 in forum Audi A4 - B8 Forum - 2008 - 2015
    Last Post: 03-11-2011, 08:19 PM
  4. Can Audi Music Interface be retrofitted to TT?
    By toot3954 in forum In Car Entertainment
    Last Post: 23-04-2009, 07:32 PM
  5. Audi Music Interface
    By richcyp in forum Q7 - 4L Forum - 2006 - 2015
    Last Post: 02-12-2008, 09:37 AM
