Thread: Passenger Mirror Tilt on Reverse
Results 1 to 8 of 8
  1. Passenger Mirror Tilt on Reverse
    Jul 2013
    76 Post(s)
    Does this work on a non folding mirror on an A6 (59/10 plate).
    If so what is the VCDS enable instructions?
    Thanks for your help.
    Dan
  2. Re: Passenger Mirror Tilt on Reverse
    46 Post(s)
    Yep it will work on all facelift cars.
    Go into your passenger door module (52) and you'll find it in there in coding, long coding helper, tick it, turn the car off, select the left hadn mirror and select reverse.
  3. Re: Passenger Mirror Tilt on Reverse
    Jul 2013
    76 Post(s)
    Thanks A6_Chris.
    You Know your Stuff, am i right in think that this can be done to both side just by selecting the RH aswell.
    Dan
  4. Re: Passenger Mirror Tilt on Reverse
    46 Post(s)
    No harm in checking the drivers door module too Dan.
  5. Re: Passenger Mirror Tilt on Reverse
    Jul 2013
    76 Post(s)
    Thanks, my English tonight has been shocking. i will edit tomorrow.
  6. Re: Passenger Mirror Tilt on Reverse
    46 Post(s)
    I blame my iPad for any spelling errors
    But I do get what you're saying, you'd have to enable it in the drivers door module too for the rh mirror selector to work, that's if the drivers door module supports it.
  7. Re: Passenger Mirror Tilt on Reverse
    Jul 2013
    76 Post(s)
    Passenger side enabled today.
    Will do the driver's once I have seen this in operation a few times.
    Many thanks
    Dan
  8. Re: Passenger Mirror Tilt on Reverse
    46 Post(s)
    Excellent
  1. C6 Mirror Tilt on Reverse
    By dingle46 in forum Audi A6 - C6 Forum - 2005 - 2010
    Last Post: 08-04-2014, 08:26 PM
  2. Mirror dip on reverse issue?
    By Wuffles in forum Audi A6 - C7 Forum - 2011- 2018
    Last Post: 11-02-2013, 10:37 PM
  3. Dipping door mirror on reverse
    By piotrek in forum Audi A6 - C6 Forum - 2005 - 2010
    Last Post: 19-08-2011, 06:24 PM
  4. Replies: 1
    Last Post: 25-05-2009, 10:52 AM
  5. S3 passenger mirror dip when "reverse" is engaged
    By steveR32 in forum Audi A3 - Archive Topics
    Last Post: 15-02-2008, 09:12 AM
