Thread: V5 oil filter drain plug
  1. V5 oil filter drain plug
    Dec 2009
    southampton uk
    The plug has been ruined and I doubt if the filter has been changed for sometime.The plug is made of alloy for some reason and that's caused the allen hole to be rounded off.I hope to replace it if I can get the filter cover off.Any tips on how to get the old plug out?
  2. Re: V5 oil filter drain plug
    Pembrokeshire
    22 Post(s)
    not sure what size it is, but normally an allen bolt can be removed by hammering a torx bit into it, or even a spline bit of the right size.
  3. Re: V5 oil filter drain plug
    Dec 2009
    southampton uk
    Thanks zollaf.I have tried forcing something in there but wary of hammering too hard cos its screwed in the plastic cover which could break and its full of oil!The alloy is just too soft andfails to stand up to any force.No doubt it was overtightened .I will have to get the cover of as it is and probably buy a new one £45 with the drain plug! Stupid idea not to use a canister filter or at least a steel plug
  4. Re: V5 oil filter drain plug
    Dec 2009
    southampton uk
    Changed the cap after taking out the new plug which was very tight .Put some copperease on it so it should come out next time.The old filter looked very tired so it needed another.The book said 3.9 ltrs but had to use nearly 5 to get to full and the old oil measured about 4 and that was near the min and excludes filter so I assume the book is wrong unless the dipstick lies!Still couldn't get the old plug out even on the bench
  1. Please Help What is best way to repair the oil drain plug thread on 58 plate 2.0 tdi a4?
    By battmiceter in forum Audi A4 - B8 Forum - 2008 - 2015
    Last Post: 21-10-2012, 05:54 PM
  2. Changing Oil - what plug do I pull to drain existing oil
    By jalz in forum Audi A3 - Archive Topics
    Last Post: 22-01-2009, 08:26 PM
  3. Oil drain plug
    By linners in forum Audi A4 - B6 Forum - 2002 - 2005
    Last Post: 12-11-2008, 11:14 PM
  4. Oil Drain Plug (or Sump) Removal Problem
    By Chromate in forum Golf MK3 - 1993 - 1999
    Last Post: 05-03-2008, 12:41 AM
  5. Engine Oil Drain Plug Mk5 Golf FSI
    By brentos2004 in forum Golf MK5 - 2004 - 2009
    Last Post: 19-01-2008, 04:17 PM
