Thread: parking sensors Open or Short to Ground after resetting
  1. parking sensors Open or Short to Ground after resetting
    Jul 2013
    Colchester, UK
    So the problem was two rear sensors weren't working,(checked for pulsing) so i decided to do a scan and after first scan i've got this:
    4 Faults Found:
    01547 - Sensor for Parking Aid; Rear Mid-Right (G205)
    009 - Open or Short to Ground
    Freeze Frame:
    Fault Status: 01101001
    Fault Priority: 3
    Fault Frequency: 18
    Reset counter: 95
    Mileage: 0 km
    Time Indication: 0
    Date: 2000.01.01
    Time: 00:00:00
    01549 - Supply Voltage for Parking-Aid Sensor
    Freeze Frame:
    Fault Priority: 3
    Fault Frequency: 30
    Reset counter: 159
    Mileage: 0 km
    Time Indication: 0
    Date: 2000.01.01
    Time: 00:00:00
    01548 - Sensor for Parking Aid; Rear Right (G206)
    004 - No Signal/Communication
    Freeze Frame:
    Fault Status: 01100100
    Fault Priority: 3
    Fault Frequency: 39
    Reset counter: 93
    Mileage: 0 km
    Time Indication: 0
    Date: 2000.01.01
    Time: 00:00:00
    002 - Lower Limit Exceeded
    Freeze Frame:
    Fault Status: 01100010
    Fault Priority: 3
    Fault Frequency: 27
    Reset counter: 159
    Mileage: 0 km
    Time Indication: 0
    Date: 2000.01.01
    Time: 00:00:00
    then i reset faults and after that i've got this:
    2 Faults Found:
    Freeze Frame:
    Fault Priority: 3
    Fault Frequency: 1
    Reset counter: 190
    Mileage: 0 km
    Time Indication: 0
    Date: 2000.01.01
    Time: 00:00:00
    Freeze Frame:
    Fault Priority: 3
    Fault Frequency: 1
    Reset counter: 190
    Mileage: 0 km
    Time Indication: 0
    Date: 2000.01.01
    Time: 00:00:00
    when ignition on and in reverse i tried to hear does any of them working and non of them were working anymore. what's happened? and how to fix it?
  2. Re: parking sensors Open or Short to Ground after resetting
    46 Post(s)
    Check all your fuses - 01549 - Ross-Tech Wiki
  3. Re: parking sensors Open or Short to Ground after resetting
    Jul 2013
    Colchester, UK
    All the fuses are good. Just checked them once again,100 % no blown ones
  4. Re: parking sensors Open or Short to Ground after resetting
    Jul 2013
    Colchester, UK
    any more suggestions?
  5. Re: parking sensors Open or Short to Ground after resetting
    Aug 2009
    Taunton UK
    it is weird twpo sensor didnt worked and other two did. But you got that problem whioch you had on the beggining. I would check wiring and connectors under the rear bumper as well .
  1. Update On Door Handle Touch Sensor (G418) 007 - Short to Ground
    By 66Cobra in forum Q7 - 4L Forum - 2006 - 2015
    Last Post: 08-04-2012, 10:05 PM
  2. Door Handle Touch Sensor (G418) 007 - Short to Ground
    Last Post: 28-03-2012, 07:38 PM
  3. Please Help Fault code 17903 - Switch-Over Valve for EGR Cooler (N345): Open or Short to Ground
    By Michael Blythe in forum Audi A3 - 8P - 2004 - 2012
    Last Post: 03-01-2012, 05:29 PM
  4. Ground Earth Short
    By v12bug in forum VCDS - Help Requests
    Last Post: 08-08-2010, 04:39 PM
  5. Please Help 00518 - Throttle Position Sensor (G69) 31-10 - Open or Short to Ground - Inter
    By Housemaster300 in forum Golf MK3 - 1993 - 1999
    Last Post: 26-07-2010, 12:05 PM
