Thread: If carlsberg did a wiper system would it be this good?
  1. If carlsberg did a wiper system would it be this good?
    Sep 2011
    Lurking over a keyboard ...
    Hi peeps !
    Today I was attaching the wiper arms to my car ... as usual I taped up areas on the screen to align them ...
    Drivers side Dimension = 30 ... 40 mm
    Passenger side Dimension = 10 ... 15 mm
    Dimensions indicate distance between tips of wiper blades and black cowl panel grille at bottom edge of windscreen
    Now I used to wander why the wipers would occasionally do a twitch up down sometimes at ignition off ...
    Well today I found out ...
    Every second time the wiper motor is switched off it runs back slightly after reaching the end position, which turns the lip of the wiper blade in the opposite direction.
    So peeps wiper blade is always in correct position ...
    But
    The wiper motor moves the wiper arms down beyond their end position and then back up slightly. This slightly raised position must not be used when aligning the wiper crank.
    You must use the end setting at which the wiper motor moves directly to its park position (without returning). Operate the “touch-wipe function” again as necessary.
    Ahhh! perfect ...
    3 2 0
  2. Re: If carlsberg did a wiper system would it be this good?
    Nov 2012
    Somerset UK
    Pics of your 'taping up' would have been good, thanks for the info though!
  3. Re: If carlsberg did a wiper system would it be this good?
    Jun 2006
    Hey Gup,
    Good info, I wondered why the wipers moved slightly, clever stuff.
  4. Re: If carlsberg did a wiper system would it be this good?
    Sep 2011
    Quote Originally Posted by MarkTM View Post
    Will do ASAP ...
    Quote Originally Posted by apole View Post
    It's
    all due to VAG men in white coats! ...
  1. Replies: 3674
    Last Post: 28-06-2017, 12:52 PM
  2. Replies: 1
    Last Post: 12-06-2011, 08:41 PM
  3. Replies: 4
    Last Post: 29-08-2010, 04:00 PM
  4. Redex, fuel system cleaner - is it any good?
    By genix in forum Golf Plus
    Last Post: 05-07-2010, 11:03 PM
  5. A3 Faulty Wiper system
    By Ed. in forum Audi A3 - Archive Topics
    Last Post: 08-03-2007, 11:31 PM
