Thread: Engine starting problems Vag code fault codes listed
  1. Smile Engine starting problems Vag code fault codes listed
    Oct 2006
    bedfordshire
    AUDI A4 1.8T SALOON 2001 Hi all my car has developed another fault I am having trouble starting it takes three gos sometimes to get going.
    I my self a major DIYER if it can be fixed I will try my best to. This site and ilexa.co.uk "are the best". I hope to think that some of my posts have helped others, I now use my old laptop with vagcom this I hope will save me from having to pay high hourly rates at main dealers.
    Vag com fault codes are.
    Chassis Type: 8E - Audi A4 B6
    Scan: 01,02,03,08,09,15,16,17,26,36,37,45,46,55,56,63,76
    Address 01 -------------------------------------------------------
    Controller: 8E0 906 018 B
    Component: 1.8L R4/5VT 0004
    Coding: 11501
    Shop #: WSC 63351
    WAUZZZ8E12A057318 AUZ6Z0A0119801
    2 Faults Found:
    16727 - Camshaft Position Sensor (G40): Signal too High
    P0343 - 35-00 - -
    16396 - Bank 1: Camshaft A (Intake): Advance Setpoint not Reached (Over-Retarded)
    P0012 - 35-00 - -
    Readiness: 0000 0100
    Ross tech detailes for fault code 16393
    Possible Causes
    Intake Camshaft Adjuster tight/stuck "Any idea where the adjuster is so I can have a look".
    Intake Camshaft Adjuster faulty
    [edit]Possible Solutions
    Check Intake Camshaft Adjuster how do I check this out.
    I HOPE EVERYONE FIDS THIS SITE AS HELPFUL AS I DO.
  2. Re: Engine starting problems Vag code fault codes listed
    Hello mate, I have the same car and the same codes have come up. The light came on and when I tried to start it again it took a while. It now drives very flat and is difficult to start when warm. I'd like to try and sort it myself so was hoping for some ideas??
  1. Vag Com Fault Codes
    By bobdobelina in forum Golf - Jetta - Vento - Bora - Archive Topics
    Last Post: 30-08-2007, 12:50 PM
  2. Can I clear the fault codes with shareware VAG-COM?/Error Code- Potentiometer for EGR
    By ardasaliah in forum Golf - Jetta - Vento - Bora - Archive Topics
    Last Post: 12-06-2007, 07:37 PM
  3. vag com fault codes
    By Dozz in forum Audi A4 - Archive Topics
    Last Post: 10-06-2007, 12:45 AM
  4. Fault codes
    By andyd118 in forum Audi A4 - B5 Forum - 1995 - 2002
    Last Post: 17-05-2007, 10:27 PM
  5. Engine starting fault after timing belt change
    By MrPassat in forum Chat - Completely Off Topic
    Last Post: 18-02-2007, 11:10 PM
