Thread: Drivers door not locking/mirror not operating
Page 2 of 2 FirstFirst 12
Results 11 to 18 of 18
  1. Re: Drivers door not locking/mirror not operating
    Sep 2007
    Will the airbag light go out once repaired or replaced ?
  2. Re: Drivers door not locking/mirror not operating
    Jan 2012
    Coding Something
    As I advised, you would be best to just buy the repair wires & repair it that way, if done properly, then it should be fine ongoing.
    The repair wires replace the wires in the multiplug, so new pin ends included & then can be cut in half to make 2 wires.
  3. Re: Drivers door not locking/mirror not operating
    Sep 2007
    Did not realise about getting new wire with pins.Pretty much knocked now then as there are 13 wires.Go for the new loom then what do you think.
  4. Re: Drivers door not locking/mirror not operating
    Jan 2012
    Coding Something
    New looms can be very expensive, tbh I would buy a used loom & cut the wires of & use these to repair with, as if its £20 or so for used loom, that's allot cheaper than some wires alone from vag.
  5. Re: Drivers door not locking/mirror not operating
    Sep 2007
    Do you not think its wise just to fit a secondhand one from eBay without cutting the wires.Fit complete or is it a difficult task ? Thanks again for your help.
  6. Re: Drivers door not locking/mirror not operating
    Jan 2012
    Coding Something
    Difficulty is down to the fitters technical abilities, if its the right one then no harm in trying, good luck
  7. Re: Drivers door not locking/mirror not operating
    #17
    Sep 2007
    Cheers will see what happens once I obtain a replacement,thanks for your help.appreciate it.Maybe be back for more assistance no doubt with my luck.Cheers all the best.
  8. Re: Drivers door not locking/mirror not operating
    #18
    Sep 2007
    Removed the loom yesterday and repaired broken wires on a temp basis,a lot easier while on the bench and in your hand.Purchased a replacement from ebay and fitted today.Pleased everything working fine now.Thanks again for all the help and hints.Cheers
  1. Replies: 3
    Last Post: 23-03-2013, 10:15 PM
  2. Problems with drivers door mirror
    By bigdilly in forum Passat - B6 Forum - 2005 - 2010
    Last Post: 14-05-2010, 11:42 AM
  3. Question door mirror Drivers/Nearside
    By cramo in forum Early Passat Forum - Pre 97
    Last Post: 28-09-2009, 05:46 PM
  4. removing drivers door mirror, HELP!
    By Ollie D in forum Golf MK4 - 1999 - 2004
    Last Post: 26-08-2008, 09:40 PM
  5. Drivers heated door mirror
    By crazycats` in forum Audi A4 - B6 Forum - 2002 - 2005
    Last Post: 22-11-2007, 07:05 PM
