Thread: Audi A6 brake light fog light interaction
Results 1 to 10 of 10
  1. Question Audi A6 brake light fog light interaction
    Jul 2007
    Oxford, England
    Hi there,
    Do the brake lights operate differently when the rear fog light is turned on?
    I have a 54 reg Audi A6 saloon, and when the rear fogs are on the outer brake lights don't operate (the inner pair and the one in the rear screen do).
    It confused the MOT tester today, and has now confused me. I have never used the rear fog light and the MOT place is also new to me, so I have no idea whether this is new behaviour or whether it was designed that way. I don't want to chase after a non-problem, but can't find any documentation on it.
    Thanks,
    Matt
  2. Re: Audi A6 brake light fog light interaction
    46 Post(s)
    yes thats right, when braking only the two inners operate and the far outer right stays off and is reserved for the fog light on both sides.
    thats on the non-led cluster. led cluster only has one fog on the os and one reverse light on the ns
  3. Re: Audi A6 brake light fog light interaction
    Jul 2007
    Oxford, England
    Yes, sorry. I have non-LED.
    Can you confirm that the brake lights function differently depending on whether the rear fog light is on.
    Mine certainly does.
    Thanks,
    Matt
  4. Re: Audi A6 brake light fog light interaction
    46 Post(s)
    a friend of mine round the corner has non-led clusters in his se a6 so i'll go and see him now.
  5. Re: Audi A6 brake light fog light interaction
    46 Post(s)
    brake - two inners
    rear fog - outer light on both sides
    brake and fog - only the inner brake light on both sides.
    led prefacelift clusters no difference when brake and fog are on.
    seems perfectly normal to me.
    1 1 0
  6. Re: Audi A6 brake light fog light interaction
    May 2013
    Southend, Essex
    On mine it's the outers, not the inners that are the brakes
  7. Re: Audi A6 brake light fog light interaction
    46 Post(s)
    Yours is an avant, not saloon
  8. Re: Audi A6 brake light fog light interaction
    May 2013
    Southend, Essex
    That's true! I hadn't noticed that the saloon was different but then it's not exactly a common car so I've not been aware of following one
  9. Re: Audi A6 brake light fog light interaction
    Jul 2007
    Oxford, England
    brake - two inners
    Excellent, so it was designed that way and the MOT tester was being overly cautious. Great news.
    Thanks so much for your help,
    Matt
  10. Re: Audi A6 brake light fog light interaction
    46 Post(s)
    Yep seems designed like that, from memory I can remember mine acted like this too before I had mine changed to LED.
    Always happy to help
  1. 2004 A6 3.0 TDI Quattro rear fog light and reverse light problem
    By Chris1965 in forum Audi A6 - C6 Forum - 2005 - 2010
    Last Post: 08-01-2013, 01:30 PM
  2. Golf mk 5 reverse light and fog light swap for lhd rules
    By mojorising in forum VCDS - Help Requests
    Last Post: 21-04-2012, 09:33 AM
  3. Brake light changed diesel coil light and brake light still on
    By Manny.p in forum Audi A4 - B6 Forum - 2002 - 2005
    Last Post: 15-09-2010, 02:04 PM
  4. Rear fog light / reverse light fault (golf 5)
    By 85turbo in forum VCDS - General Questions
    Last Post: 03-09-2010, 11:30 PM
  5. Please Help Audi A4 - rear fog light
    By The Man in forum Audi A4 - B6 Forum - 2002 - 2005
    Last Post: 10-04-2009, 09:04 PM
