Thread: Audi a3 2003 a3 tdi 2.0 ESP reset issues vagcom, desperate for mot!
Page 2 of 2 FirstFirst 12
Results 11 to 19 of 19
  1. Re: Audi a3 2003 a3 tdi 2.0 ESP reset issues vagcom, desperate for mot!
    Jul 2013
    blackpool
    cheers mate been searching around for answers and seen that i may need a new abs module, hopefully not and just found this so will give it a goBrake Pressure Sensor 1 (G201)
    Prerequisites:
    • System voltage at least 12.0 V.
    [Select]
    [03 - Brake Electronics]
    [Measuring Blocks - 08]
    Group 005
    [Go!]
    Check field 1, the value has to be between -8.0 and +8.0 bar.
    [Done, Go Back]
    [Coding-II - 11]
    OR (if Coding-II is not available)
    [Security Access - 16]
    Enter 40168, to enable the basic setting.
    [Do it!]
    [Basic Settings - 04]
    Group 066
    [Go!]
    Activate the Basic Setting.
    [ON/OFF/Next]
    After a successful basic setting, field 2 should say "OK".
    [Done, Go Back]
    To make sure the basic setting was succesful, check the sensor again.
    Group 005
    [Go!]
    Check field 1, the value has to be between -3.8 and +3.8 bar.
    [Done, Go Back]
    [Close Controller, Go Back - 06]
    • Malfunction Indicator Light (MIL) active
    Possible Causes
    • Sensor 1/2 for Brake Pressure faulty
    Possible Solutions
    • Check/Replace Sensor 1/2 for Brake Pressure
    Special Notes
    • In cases where the Sensor for Brake Pressure is part of the Brake Hydraulics Unit, the complete Unit may need to be replaced.
  2. Re: Audi a3 2003 a3 tdi 2.0 ESP reset issues vagcom, desperate for mot!
    Jul 2013
    blackpool
    now having problems with my cable ffs, its an official rosstech one aswell. Sorry this function requires a licensed interface, even though it worked on all modes earlier then a little later had restricted the basic settings tab for example which i needed to click to finish my checks.
    really didnt think id have all these electrical issues with an Audi thought id let that ****** ship sink with my 306
  3. Re: Audi a3 2003 a3 tdi 2.0 ESP reset issues vagcom, desperate for mot!
    46 Post(s)
    contact ross tech as you have a genuine cable or pm bearthebruce on the forum
  4. Re: Audi a3 2003 a3 tdi 2.0 ESP reset issues vagcom, desperate for mot!
    Jul 2013
    blackpool
    also checked the brake pressure and was within the set parameters -8.0 and +8.0 bar., so assume the switch isnt faulty or completely faulty, might just have to take it in somewhere soon as i need it back on the road just cant afford to shell out for unjustified parts and labour
  5. Re: Audi a3 2003 a3 tdi 2.0 ESP reset issues vagcom, desperate for mot!
    Jul 2013
    blackpool
    turns out its not a ross tech cable i have gonna try get my money back fromn the seller on ebay as its useless to me, is direct from ross tech the best option for what i need? dopnt want to be relying on audi at all cant afford
  6. Re: Audi a3 2003 a3 tdi 2.0 ESP reset issues vagcom, desperate for mot!
    Oct 2005
  7. Re: Audi a3 2003 a3 tdi 2.0 ESP reset issues vagcom, desperate for mot!
    #17
    Jul 2013
    blackpool
    So id be looking around the £250 mark? might be better for me to get someone local or someone with a cable to have a look for me then would be a fair bit cheaper id imagine
  8. Re: Audi a3 2003 a3 tdi 2.0 ESP reset issues vagcom, desperate for mot!
    #18
    Oct 2005
    Depends if you're planning on keeping the car for a long time or not.
    It'll pay for itself after 3 scans.
  9. Re: Audi a3 2003 a3 tdi 2.0 ESP reset issues vagcom, desperate for mot!
    #19
    Jul 2013
    blackpool
    Just checked my warrantee with the car as I got some gold customer care package with my checked the fine print and looks as though its covered I've just gotta pay the diagnostic charge at £50, they said I could use halfords for the work as they're linked but said next wendsday earliest, I used to work on the bike dept in halfords 10 years back and remember the car dept been pretty **** in reputation and service, however could take it to any garage with a labour rate of up to £47 or so, what would you guys reccomend I'm guessing a strong steer clear of halfords for a start?
  1. Please Help GT TDI 150 2003 ESP and knocking
    By bonerp in forum Golf MK4 - 1999 - 2004
    Last Post: 04-07-2012, 08:27 AM
  2. Please Help 2003 Passat 1.9 TDi Brake and Clutch Problem - ESP and ABS lights on
    By Stuartd77 in forum Passat - B5 Forum - 1997 -2005
    Last Post: 09-08-2011, 09:20 AM
  3. which cable for vagcom for 2003 a4 tdi
    By nickeym1 in forum Audi A4 - B6 Forum - 2002 - 2005
    Last Post: 29-01-2011, 09:52 PM
  4. Question 2003 A4 V6 TDi starting issues and is my car can bus ?
    By ShaunD in forum Audi A4 - B6 Forum - 2002 - 2005
    Last Post: 01-02-2009, 04:27 PM
  5. Audi A3 2003/53 Boot & Rear Wiper issues
    By alistairr24 in forum Audi A3 - Archive Topics
    Last Post: 04-02-2008, 04:10 PM
