Thread: VAGCOM Help Please!
Results 1 to 8 of 8
Hybrid View
  1. VAGCOM Help Please!
    Mar 2007
    Lancashire
    I've read the Ross-tech FAQ and as many thread with VAGCOM as possible but my issues are not resolved.
    I've just got a Ross-Tech Hex-Com duel-K. I've downloaded and installed version 704.1 of the software. I connected the cable to the car ok and green light came on. It's a serial connection by the way. Performed test, all ok on com1. Now the problem I have is that it keeps losing the interface. If I try and check engine-01 for example it will try several attempts then say Interface Status = -2, following errors:-
    Interface not ready - well green light is on cable
    Incorrecet com prot - tested ok
    Interface not plugged - it is
    Ignition off - I'm not that stupid
    K-line stuck - Not sure what that means
    Firmware update required - I assume all was latest download and ok!
    When I perform the test it can be ok sometimes, saying:-
    Hex-com
    V1.78
    K1 OK
    K2 OK
    I have had it working ok for 5 mins, then I lost connection, "interface not found". Reboot, re -plug all ok. Same again after 10 mins. Cable light always stays green.
    Could anyone shed any light on this for me please, as I 'm at the point of contacting seller (from ebay) re the cable. I can't see cable being a problem as it will work.
    Am I using correct software v704.1 for the B6 model. I know some of you use v4**. Any help most welcome.
    Mark
  2. Re: VAGCOM Help Please!
    Canada
    If you have a 3rd party cable you can only use older versions of vag-com.
    look here
    http://www.ross-tech.com/vag-com/faq_3.html#3.2
  3. Re: VAGCOM Help Please!
    Mar 2007
    Lancashire
    Hi, Thanks for reply onzarob. I thought that, and advertised by the seller on ebay, that buying a genuine Ross-tech cable would not be 3rd party. I have attached a pic of the cable with all the Ross-tech blurb on it.. I thought I would be able to use the latest software with this. Like I said, it has worked but the connection keeps dropping! Should there be a different version of software to use?
  4. Re: VAGCOM Help Please!
    Canada
    it looks genuene so should work, if it doesn't contact ross-tech or send it back, is it new or used?
  5. Re: VAGCOM Help Please!
    Mar 2007
    Lancashire
    I'm not sure to be honest. The cable didn't come in any packaging other than bubble wrap, so I assumed used. Still it should be ok. Like I said, it will work but then decides to stop. I hate intermittent problems! I'll contact the seller and see if I can get some history on it.
  6. Re: VAGCOM Help Please!
    Mar 2007
    Lancashire
    I appear to have got it working consistantly now but still not accessing everthing. I un-installed some redundant apps from the laptop that could cause connection issues (Ross-tech FAQ page). The trouble I have now is that I can't access various options in the control module. If I got to Common and select 01-Engine, then I get the information ok. If I select Drivetain try 11-Engine, 21 Engine, 31 Engine other for example, then I get "No response from contoller!" see image below. Instruments and ABS brakes give me info ok but many others don't. I've got a fully registered/activated account.
    Anyone else had these problems?
  1. Vagcom brief
    By paddymm in forum VCDS - General Questions
    Last Post: 18-02-2010, 08:58 AM
  2. VagCom???
    By Mig 117 in forum Golf - Jetta - Vento - Bora - Archive Topics
    Last Post: 23-07-2007, 06:37 AM
  3. Help with a vagcom code
    By Dozz in forum Audi A4 - B6 Forum - 2002 - 2005
    Last Post: 29-06-2007, 03:52 PM
  4. Which Vagcom do I buy
    By Dozz in forum Audi A4 - Archive Topics
    Last Post: 07-06-2007, 11:32 AM
  5. Anyone with Vagcom online now?
    By M4YTY in forum Passat - Archive Topics
    Last Post: 09-04-2007, 09:38 PM
