Thread: Brake bleeding sequence confusion - little help please!
Page 1 of 3 123 LastLast
Results 1 to 10 of 21
  1. Brake bleeding sequence confusion - little help please!
    May 2012
    Glasgow
    Howdy, so I replaced a rear brake line that had ruptured last night,
    lots of brake fluid loss so obviously I'm bleeding clutch then brakes
    to be safe.
    On every other car that I've worked on bleeding sequence is the conventional furthest caliper from master cylinder working back to closest but I've read on the web people both confirming this and suggesting left front, right front, left rear, right rear instead.
    Which is right?, and if its not the conventional sequence does anyone know why?, to do with abs system?,
    any thoughts appreciated, especially a definitive answer as I could do with getting the car back on the ground tonight!
    cheers!
    2001 A6 Avant 1.9tdi 130 manual AWX 203k+++ "Come to kindly terms with your @ss for it bears you." - John Muir.
  2. Re: Brake bleeding sequence confusion???, little help please!
    Nov 2011
    Duns Scotland
    11 Post(s)
    Quote Originally Posted by mrnice View Post
    to be safe.
    cheers!
    Hi - had the same confusion! I have just checked again for you and, ELSAWIN says:
    IF CHANGING BRAKE FLIID: As YOU say, LF, RF, LR, RR (This is procedure I have used for last 6 years)
    BUT...
    IF BLEEDING BRAKES: RF, LF, RR, LR
    Ours is not to reason why.....!
  3. Re: Brake bleeding sequence confusion???, little help please!
    May 2012
    Glasgow
    There's so many differing opinions on this it almost seems that it'll work both ways but better one way. Seems to be the Audi techs/aficionados saying the unconventional method is the way to go, and being an Audi that doesn't surprise me so I'll just go that way..
  4. Re: Brake bleeding sequence confusion???, little help please!
    May 2012
    Glasgow
    Quote Originally Posted by ceilidhalfie View Post
    BUT...
    Thanks!, if someone savvy has done it and it worked that's good enough for me, there was fluid loss but the res didn't run out, at least this'll be my brake fluid changed I guess!
  5. Re: Brake bleeding sequence confusion???, little help please!
    Nov 2011
    Duns Scotland
    11 Post(s)
    I would not be too concerned. Go with one way - if it works you will have stiff brakes, if not they will be spongy and you will have to bleed again - THE OTHER WAY!
  6. Re: Brake bleeding sequence confusion???, little help please!
    Nov 2011
    Duns Scotland
    11 Post(s)
    Forgot to add - make sure you use a quality fluid. I once bought cheapo Hafords stuff and had to redo after a month!
  7. Re: Brake bleeding sequence confusion???, little help please!
    It depends on which version of ESP you have 5.3 or 5.7 You tell us. You may need VCDS to bleed the ESP/ABS pump. Regards Peter
  8. Re: Brake bleeding sequence confusion???, little help please!
    May 2012
    Glasgow
    I have no clue Peter, how do I find out?.
    I've made the assumption that since the fluid didn't go below min on the res that
    I didn't need to touch abs.
    For the record it says Bosch on the unit along with several different long numbers.
    I'll soon see how it's all working I guess.
  9. Re: Brake bleeding sequence confusion???, little help please!
    Nov 2011
    Duns Scotland
    11 Post(s)
    If you have VCDS, run a scan. When it comes to the ABS Brakes control module, VCDS shows the ESP version right at the top of the display.
    What Peter means is if it is ESP 5.3, you have the pump which may need bleeding (via VCDS). This is not a issue with ESP 5.7 as there is no pump.
  10. Re: Brake bleeding sequence confusion???, little help please!
    May 2012
    Glasgow
    I get it, thanks for that, I only have VCDS lite so not sure i'd be able to do the abs bleeding anyhow. Haven't found where it refers to either esp 5.3 or 5.7 tho,
    This is what I'm getting for auto-scan and abs brakes module-
    [/URL]
    [/URL]
    Please excuse my general ignorance, still new to 'modern' motoring and this is the first diagnostic software I've used.
    Many thanks for the replies
  1. Bleeding brake system!
    By day in forum Golf MK4 - 1999 - 2004
    Last Post: 28-07-2018, 04:04 PM
  2. Please Help Brake bleeding sequence ibiza 2007
    By JZ IBIZA in forum Ibiza - Cordoba
    Last Post: 20-02-2010, 04:52 PM
  3. Please Help brake bleeding
    By coyotee in forum Audi A3 - Archive Topics
    Last Post: 20-06-2008, 11:12 AM
  4. Question A6 brake bleeding.
    By lloydj2 in forum Chat - Anything with wheels
    Last Post: 12-05-2008, 10:08 PM
  5. Brake bleeding
    By woodburner in forum Passat - B5 Forum - 1997 -2005
    Last Post: 02-01-2008, 08:10 PM
