Thread: Parrot mki9200 fit into golf mk5
  1. Parrot mki9200 fit into golf mk5
    daniel408 Guest
    Hey guys,
    I've had a quick scan over the forums looking for my answer but so far no luck. I've recently purchased a parrot MKi9200 and the SOT976 lead from halfords. My radio is the standard golf radio which plays mp3 cd's, I think it's the rcd 300. On the parrot cable loom there is a yellow telemute cable and 3 corresponding cables which say "mute 1,2,3" on them. Does anyone out there know which one i should connect to? Below are 2 links, the top one is to a picture which is the same as the sticker on the back of my radio, the bottom is the parrot wiring diagram for the loom and SOT cable.
    http://Www.tyresmoke.net/attachments...box-pinout.jpg
    http://dbinstall.parrot.com/pdf.php?...KI9200&lang=GB
    many thanks.
    Dan
  2. Re: Parrot mki9200 fit into golf mk5
    Jan 2012
    Coding Something
    Cant see the 1st link, but I would hazard a guess Parrot loom is just providing 3 pin locations for mute, so depending on which head units are used determines which wires are used, just look for the mute pin on the head unit which maybe C10 of the quadlock connector & match up the pin from there, through your various looms to connect to the parrot mute wire, should be simple tbh.
  1. Parrot MKI9200 Rip Off/recommended installers?
    By edmond in forum In Car Entertainment
    Last Post: 23-05-2011, 10:06 PM
  2. Question Parrot MKi9200 in a Passat B5.5
    By Jamiem in forum In Car Entertainment
    Last Post: 15-12-2010, 05:28 PM
  3. Bury CC9060 v Parrot CK3100 v MKi9200
    By theblarney in forum Home Tech Shed
    Last Post: 27-05-2010, 12:55 AM
  4. Parrot MKI9200
    By a4_cab in forum Audi A4 - B7 Forum - 2005 - 2008
    Last Post: 05-01-2010, 10:20 PM
  5. Parrot MKi9200 in a New Golf V
    By ipilot in forum In Car Entertainment
    Last Post: 18-12-2008, 10:01 PM
