I can't see that this has been discussed on the forum yet. I was wondering if anyone had any ideas what the differences are between Normal, Sport and Eco (excluding DSG and DCC). The way I see it is as follows:
Aircon - fairly straight forward. Normal is colder than Eco.
Steering - again, fairly straight forward. Sport is heavier than Normal.
ACC - Sport gets you up to speed and slows you down quicker. Eco accelerates much slower. Normal seems to be a balance.
Engine - I'm not sure about this one... It seems to me that the only difference is a change in the throttle response map. Sport has a steeper line to Eco - i.e. Sport is more sensitive to movements in the pedal and gets to full throttle sooner. For example, when the accelerator is half pressed, in Sport the pipe is 3/4 open, whereas in Eco it's only 1/4 open (simple example, but you get the point). I find i can get the same performance from the car in Eco as I can in Sport, I just have to push the pedal more.
I don't think there's any remapping of the ECU for two reasons: 1. ECU's remap differently and wouldn't it be dangerous to just change these instantly. 2. When mentioning the low fuel economy on diesels, the dealer said that the ECU had to "learn my style of driving", which implies that the ECU can't change that quickly (?).
If I'm right about the above, then Eco mode won't so that much. But an aggressive throttle response sure is fun
Anyone else's thoughts???
