Thread: Audi A3 1.9tdi BKC 2005 8PA No turbo power
  1. Audi A3 1.9tdi BKC 2005 8PA No turbo power
    semiret Guest
    At the weekend thought I would clean up the two lower pipes to and from the intercooler as the one from the turbo was looking very gungy. Removed both and cleaned them up. I did not touch anything else. Car started fine today but was clear during my journey that something was wrong with no power from the turbo. Ran fine but was lacking in power due to no turbo. Car was running normal before I worked on car and all I did was clean the lower pipes. Could it be that the gaskets on these pipes are not now sealing, not sure if this is a factor. No warning lights on dash. Any help/guidance gratefully received. Please help.
  2. Re: Audi A3 1.9tdi BKC 2005 8PA No turbo power
    Jan 2012
    Coding Something
    I would check your piping to see if its popped of or not sealed properly, it has to be this if you worked on that area & now its not right, probably something simple.
  3. Re: Audi A3 1.9tdi BKC 2005 8PA No turbo power
    semiret Guest
    Many thanks. You were right, did not push one fully home. Feel foolish now!!! Just panicked.
    You are a star.
  4. Re: Audi A3 1.9tdi BKC 2005 8PA No turbo power
    Jan 2012
    Coding Something
    It happens, don't sweat it
  1. Please Help Audi A3 8PA 1.9tdi BKC engine...glow plug connectors disintegrating
    By semiret in forum Audi A3 - 8P - 2004 - 2012
    Last Post: 01-01-2013, 03:28 PM
  2. Golf 1.9tdi BKC Engine Cambelt & Water Pump Cost?
    By golf144 in forum Golf MK5 - 2004 - 2009
    Last Post: 09-06-2012, 12:14 PM
  3. 1.9tdi (BKC) Wont start if parked on hill - HELP!
    By andwat in forum Golf MK5 - 2004 - 2009
    Last Post: 27-04-2012, 11:25 PM
  4. Please Help BKC 1.9TDI rough running
    By bigstuff in forum Passat - B6 Forum - 2005 - 2010
    Last Post: 20-09-2011, 07:33 PM
  5. A4 1.9TDI Turbo/power problem
    By MARSHY in forum Archive posts
    Last Post: 07-04-2007, 07:52 PM
