Thread: N75 location 05 2.0TDI 140bhp
  1. N75 location 05 2.0TDI 140bhp
    Jul 2013
    London
    Hi all , bought 2.0 TDI 140bhp . Seems to have low boost . My Father has a B5.5 and have located N75 , Sister has 08 B6 and this has N75 but cannot locate on the 05 . Is there a reason this has been changed back on the 08 ? Fuel filter changed , pipes checked for leaks . Is it possible someone knows where the N75 is located on 05 B6 ? Is there one ? Thanks for any info
  2. Re: N75 location 05 2.0TDI 140bhp
    Sep 2011
    Lurking over a keyboard ...
    Hi ,
    Welcome to VWAF! ...
    I searched for 2005 Passat 2.0 TDi , 2 engine codes came up, I think yours would be BGW?
    Regardless of engine code N75 is coming as being fitted, to find it follow a small hose running off the air filter cover ... P/N on it should be 1J0 906 627 A ...
  3. Re: N75 location 05 2.0TDI 140bhp
    Norfolk
    Quote Originally Posted by 1430buell View Post
    Depending on model/engine, you may not have a N75 valve. Many models have a solenoid block with several pipes attached to it. I would look for damaged pipes with a low boost code. (vacuum pipes and intercooler pipes.)
  4. Re: N75 location 05 2.0TDI 140bhp
    Dec 2011
    London
    Quote Originally Posted by martin1810 View Post
    +1 - Can confirm mines doesn't have N75 however has the big solenoid block. You can't miss it - Its on the firewall next to the battery.
  5. Re: N75 location 05 2.0TDI 140bhp
    Sep 2011
    This solenoid block is termed as N75 when searching via SDC code system ...
    The P/N I posted in post 1 has a description 'Pressure converter(for turbocharger)' ...
  1. N75 valve location
    By andyjerv in forum Audi A3 - 8P - 2004 - 2012
    Last Post: 22-04-2013, 09:49 PM
  2. Question A4 2.0tdi 140bhp - which oil?
    By bluevortex in forum Audi A4 - B7 Forum - 2005 - 2008
    Last Post: 21-07-2011, 03:19 PM
  3. 1.4tsi 122bhp or 2.0tdi 140bhp
    By lchrisl in forum Golf MK6 - 2009 - 2013
    Last Post: 19-03-2009, 05:32 PM
  4. Question Touran 2.0TDi 140bhp glowplug location
    By D.M. in forum Touran - Sharan - Caravelle
    Last Post: 16-07-2008, 06:51 AM
  5. N75 location on TDI
    By mladen in forum Audi A4 - B5 Forum - 1995 - 2002
    Last Post: 23-12-2007, 02:51 PM
