Thread: Passat 2.0 tdi 170 white smoke
Results 1 to 10 of 11
  1. Angry Passat 2.0 tdi 170 white smoke
    Apr 2013
    Darlington
    Hey there guy's excuse my writing skill's first of all, Here's my problem i bought the car not so long back 2007 with 140k and it seemed to be running fine with very little smoking. But now the problem has got worse on tick over its chuffing smoke out smell's like unburnt fuel. So i took the car to vw who first of all said they must of damaged injector seal after recall and replace them under the parts warranty, but the problem still remain's constant smoke on tickover hot or cold and abit lumpy to start.... So i went back to vw and they are now saying its down to the dpf been clogged up. So a friend checked on the vag com under measuring blocks group 68 and it came up particle filter mass carbon mass 76.98 when the max should be 60 and on group 75 temp before turbo charger 1000 oC. i get the odd loss of power/surging now and then but i aint seen the dpf light come on or eml light. Could all this be down to the dpf ?
    Also if it is the dpf would it be better going for the dpf delete and egr delete with remap to sort the problem all advice welcomed thanks guys jamie
  2. Re: Passat 2.0 tdi 170 white smoke
    Sep 2008
    SE London
    Not a Derv head here but:
    http://wiki.ross-tech.com/wiki/index.php/Diesel_Particle_Filter_Emergency_Regeneration
    and
    VW AUDI Forum - VWAF
    might help
    Post your VCDS Autoscan here. Others more knowledgable than me then can help
  3. Re: Passat 2.0 tdi 170 white smoke
    Norfolk
    It is odd that the dpf is not putting up a light or any codes. Is it possible someone has fiddled with the ecu file to hide a dpf problem? The cheapest solution may be to rip out the dpf insides and remap the ecu. The alternatives are, attempt to clean and reset yours or fit a new one. Get a vcds scan of all sensors, especially pressure sensor.
  4. Re: Passat 2.0 tdi 170 white smoke
    Apr 2013
    Darlington
    Hello there Martin, any advice on how to read all sensor's and the pressure sensor ?, Also any good company's to carry out the dpf delete. So far the dpf & egr delete and map £450 all in which isnt to bad compared to the price of a dpf
  5. Re: Passat 2.0 tdi 170 white smoke
    Norfolk
    Use vcds and read the manual on ross-tech site. This gives loads of procedures, hints, help etc. You could try a forced regen, that's on ross-tech site too.
  6. Re: Passat 2.0 tdi 170 white smoke
    DSG4ME Guest
    Are you sure this isn't a dying turbo, that will poke white smoke and smell bad also.
  7. Re: Passat 2.0 tdi 170 white smoke
    Apr 2013
    Darlington
    Hey there turbo seems fine matey, vw are blaming the dpf causing the smoke and slight missfire on startup car runs smooth at speeds and tick over. I am stumped on this problem
  8. Re: Passat 2.0 tdi 170 white smoke
    DSG4ME Guest
    Quote Originally Posted by l200jmc View Post
    I had the misfire but only in summer months, non dpf car though, I think I've traced it to bad fuel from one garage although not confirmed yet, the garage sells ESSO which should be good fuel but it's on a Tesco site so who knows what they are selling.
  9. Re: Passat 2.0 tdi 170 white smoke
    Apr 2013
    Darlington
    I use shell or bp mainly some times even the shell v power if im feeling flush lol, I hope it is the dpf, known my luck ill have it cut out mapped and egr off and it will still smoke and have poor start up :/ lol
  10. Re: Passat 2.0 tdi 170 white smoke
    DSG4ME Guest
    So long as that is what it is I would get shot of it, the benefits are improved mpg although I'm a bit dubious to this claim myself, but the engine will breath better without the spud in the exhaust.
  1. Please Help white smoke and lack of power passat tdi
    By plasticcouch81 in forum Passat - B5 Forum - 1997 -2005
    Last Post: 02-08-2009, 10:04 PM
  2. new A3 se 2.0 TDI 170 ibis white
    By pform in forum Audi A3 - Archive Topics
    Last Post: 08-03-2009, 07:10 PM
  3. Irratic Idle,white Smoke Now No Start Passat Tdi 97
    By craigdix in forum Early Passat Forum - Pre 97
    Last Post: 06-02-2009, 12:53 AM
  4. Passat woes.. white smoke but still runs well
    By jockmonkey in forum Passat - B5 Forum - 1997 -2005
    Last Post: 04-06-2008, 10:58 AM
  5. 2002 tdi white smoke ?????
    By mullac in forum Passat - B5 Forum - 1997 -2005
    Last Post: 23-07-2007, 11:20 AM
