Thread: Manifold flap intake fault code?
  1. Manifold flap intake fault code?
    Jun 2013
    Bristol
    2 VCDS fault codes were found today, I recognise the Dpf fault, does anyone recognise the manifold problem ? Codes read as follows: 012547 motor intake manifold flap v157 P103 008194 trap bank 1 P002-000 MIL On Particulate trap bank 1??? 2008 A6 2.0Tdi
  2. Re: Manifold flap intake fault code ?
    Jan 2011
    Stafford, UK
    Quote Originally Posted by davemeysner View Post
    http://www.dtcdecode.com/P2433
    <link removed> - sorry Chris.
    2009 - A6 2.7 TDI (CANA) - S Line - Avant (Multitronic) Daytona Grey.
    Ross-Tech - http://www.ross-tech.com/vcds/tour/main_screen.html
    Screen capture - FastStone Screen Capture - The Best Screen Capture Software
  3. Re: Manifold flap intake fault code?
    Jan 2011
    Stafford, UK
    Sent you a PM Dave.
  4. Re: Manifold flap intake fault code?
    Sep 2011
    Lurking over a keyboard ...
    motor intake manifold flap v157 2008 A6 2.0Tdi
    Hi ...
    i) google SSP412 Audi 2.0l 125 kW TDI Engine with Pump Injection System
    ii) Then view page 20 and you will see what the V157 is and location on engine ...
    iii) Access is not to bad to it ... there are also threads about it on here concerning peoples issue's / remedies ...
  1. Intake Manifold Flap Fault - Clean/Replace and where?
    By timdave25 in forum Audi A6 - C6 Forum - 2005 - 2010
    Last Post: 10-11-2012, 08:42 PM
  2. v6 tdi intake manifold flap fault
    By andreia in forum Passat - B5 Forum - 1997 -2005
    Last Post: 14-08-2012, 01:21 PM
  3. Intake manifold flap
    By john-mandy in forum Audi A4 - B7 Forum - 2005 - 2008
    Last Post: 20-12-2010, 11:48 PM
  4. Intake Manifold Flap Fault Codes and Cleaning
    By aceofharts414 in forum Golf MK5 - 2004 - 2009
    Last Post: 17-11-2010, 09:44 PM
  5. Motor for intake manifold flap
    By stephen k in forum Golf MK4 - 1999 - 2004
    Last Post: 31-05-2009, 05:47 PM
