Thread: Alarm Issue
Results 1 to 8 of 8
  1. Alarm Issue
    Apr 2009
    My 2003 Passat 1.9 TDi alarm goes off some time after being locked for no apparent reason. The alarm only activates the once. I've tried switching off the alarm (pressing remote locking button twice or twice locking car with key) but it still happens. Any ideas?
  2. Re: Alarm Issue
    Jun 2013
    Haverhill, Essex
    Check your rear courtesy lights/alarm sensors... had a similar issue in my bora.... changed one and it solved the issue outright.
    Beyond that I have no idea dude
    Sent from a kick *** mobile communications device
  3. Re: Alarm Issue
    try pushing the button on the drivers door pillar on the inside , it turns the interior sensors off so im informed.... for when pets are in the car.
  4. Re: Alarm Issue
    Jun 2013
    Haverhill, Essex
    It does... but from the manual its temporary and does re-arm
  5. Re: Alarm Issue
    Quote Originally Posted by Cooper B5.5TDI View Post
    does it say when it rearms ? im guessing the next time the alarm is set .
  6. Re: Alarm Issue
    Jun 2013
    Haverhill, Essex
    Think it said a short amount of time....nothing about next time its set. Will write it up when I get home
    Sent via carrier pideon
  7. Re: Alarm Issue
    Gwent
    Check for water under passenger side front carpet. If wet dry out the central convenience unit and it's wiring and clear the plenum drains (under the battery and another roughly under the servo)
    2001 Passat Sport tdi 130hp
    1990 Audi coupe 20v x 2
  8. Re: Alarm Issue
    Jun 2013
    Haverhill, Essex
    Hope this helps
  1. A6 Alarm Issue
    By Clinterous in forum Audi A6 - C5 Forum - 1998 - 2004
    Last Post: 30-06-2010, 12:19 PM
  2. a4 b5 alarm issue
    By quattrogary in forum Audi A4 - B5 Forum - 1995 - 2002
    Last Post: 16-06-2010, 09:45 PM
  3. Alarm issue
    By dap1977 in forum Golf MK5 - 2004 - 2009
    Last Post: 01-06-2010, 07:55 PM
  4. 93 golf alarm issue
    By caperdog in forum Golf MK3 - 1993 - 1999
    Last Post: 27-07-2008, 10:41 PM
  5. Alarm issue!
    By Waffs1984 in forum Passat - B5 Forum - 1997 -2005
    Last Post: 29-03-2008, 10:49 PM
