Thread: Diesel Purge liquid
  1. Diesel Purge liquid
    Dec 2011
    Swindon
    9 Post(s)
    I have been reading on the TDI forum about diesel purging liquid. Basically you buy this super lliquid, connect it straight into the fuel system (by passing the fuel filter) and going into the injectors cleaning them of carbon.
    Has anyone heard or this or done this? Did it work? Does it put the lift pump seals at risk?
    Easy Lubro Moly Diesel Purge How-To - with pics!! - Page 34 - TDIClub Forums
    Geoff
  2. Re: Diesel Purge liquid
    Aug 2011
    Meath
  3. Re: Diesel Purge liquid
    Dec 2011
    Swindon
    9 Post(s)
    ha ha. funny.
  4. Re: Diesel Purge liquid
    Aug 2011
    Meath
    Pint of petrol to half a tank of diesel once a month does the same thing which isn't much any more I suspect. It helped old style diesels with mechanical pumps for sure
  5. Re: Diesel Purge liquid
    Dec 2011
    Swindon
    9 Post(s)
    Is that something you do?
  6. Re: Diesel Purge liquid
    Aug 2011
    Meath
    Yes I do that, years ago the old boys all said to put in petrol about once a month. In those days diesel was dirty and had water in it. You never hear anyone draining the fuel filter any more. This would be done monthly years ago. Realistically if there's crap in your fuel lines, injectors etc you really don't want to suck it into your engine or blow it into the blades of your turbo. I do it because old dogs can't manage new tricks
  7. Re: Diesel Purge liquid
    Dec 2007
    Belfast
    Try searching utube for terraclean, as recommended by Ed China
    Marko.
  1. purge valve
    By nigz in forum Audi A4 - B6 Forum - 2002 - 2005
    Last Post: 17-03-2013, 05:11 PM
  2. Question Purge Valve ticking
    By PCDoctor in forum Golf MK4 - 1999 - 2004
    Last Post: 25-03-2012, 12:55 AM
  3. Attention Anyone used Diesel Purge?
    By Zeb in forum Passat - B6 Forum - 2005 - 2010
    Last Post: 20-05-2011, 07:43 PM
  4. Question Lubro Moly Diesel Purge
    By Norman vwp in forum Passat - B5 Forum - 1997 -2005
    Last Post: 15-11-2009, 01:11 PM
  5. Vagcom to purge ABS?
    By dickturpin in forum Golf MK4 - 1999 - 2004
    Last Post: 19-07-2009, 11:46 AM
