Thread: DPF pressure sensor with error 2,250,0
  1. Question DPF pressure sensor with error 2,250,0
    Jun 2013
    Leeds UK
    Golf Mk6 2.0 TDI 2009 with 36k miles. Exhaust warning light comes on (little yellow engine symbol), but can be cancelled with appropriate reader, then comes on again after no particular mileage. Fault reader indicates error code 2,250,0.
    In my case the problem was a faulty sensor which measures the pressure difference across the DPF. Replacement of this, cost £60 from Leeds VW solved the problem and job took about 25 mins. Needs a suitable torx bit and connecting tubes may need some force to get off but otherwise simple.
  2. Re: DPF pressure sensor with error 2,250,0
    Nov 2009
    46 Post(s)
    Welcome to VWAF.
    Common fault on DPF equipped models, always prone to go!
  1. DPF pressure sensor and remap
    By bennettp23 in forum Audi A6 - C6 Forum - 2005 - 2010
    Last Post: 10-02-2015, 03:19 PM
  2. Question 3,0 TDI glow plug And DPF Sensor Error codes
    By Richie Taylor in forum Audi A4 - B7 Forum - 2005 - 2008
    Last Post: 03-09-2012, 06:45 AM
  3. DPF / Boost Pressure Sensor issues...
    By A1Dan75 in forum Passat - B6 Forum - 2005 - 2010
    Last Post: 20-01-2012, 11:13 AM
  4. Failed DPF pressure sensor...
    By SportyB8 in forum Audi A4 - B8 Forum - 2008 - 2015
    Last Post: 01-04-2010, 04:37 PM
  5. 17604 02 Sensor error - VW garage says £250 to fix !
    By alex_uk in forum VCDS - Help Requests
    Last Post: 16-07-2009, 06:52 AM
