Thread: High revs no power
Results 1 to 10 of 11
  1. High revs no power
    Apr 2012
    Gabrorne; Botswana
    I have a 2000 Bora V5 engine code AGZ.Recently during this cold winter months it has developed some problem as follows; I have to start it in the morning and let it idle for some minutes or it will just be revving above 3000rpm with the engine taking quite some time to reach at least 50km/h once i get on the motorway.The gear changes are also erratic especially gear 3 and the heating system only barely blows out warm air.Took it to have some faults diagnosed yesterday and the mechanic cleared the errors which had been shown by the diagnostics though i did not get the error codes.He then told me that sometimes the ECU can throw up some errors due to some bugs in the unit needless to say the car was okay for the rest of the day but this morning it did the same thing again.I should point out that it only does this when its cold or when it's been standing for more than 8 hrs.Help will be appreciated
  2. Re: High revs no power
    Pembrokeshire
    22 Post(s)
    what temperature is it reaching as indicated by the gauge ?
  3. Re: High revs no power
    Apr 2012
    Gabrorne; Botswana
    Thanks for the reply
    The temperature goes to 90 and stays there but this morning i also noticed that the fuel consumption has risen considerably
  4. Re: High revs no power
    Pembrokeshire
    22 Post(s)
    get the computer on it with the engine hot and look at the temperatures. i think you will find the coolant sender has failed and telling the ecu its a lot cooler than it is.
  5. Re: High revs no power
    Apr 2012
    Gabrorne; Botswana
    Appreciate the reply.
    Maybe i should mention that the diagnostics was done with the engine not running just the ignition on so you suggesting that i have it done again with the engine running this time right?By the way the initial errors which came up with first diagnosis were as follows;
    1.Engine electronics - fault
    2. Transmission - fault
    Air con/Heating - fault
    Could this faults in any way be resulting from a failed coolant temperature sensor
  6. Re: High revs no power
    Pembrokeshire
    22 Post(s)
    yes, run the engine with the computer connected and looking at the live readings. the coolant temp should be around 87-92 degrees.
  7. Re: High revs no power
    Dec 2009
    southampton uk
    High revs and no speed is clutch slipping
  8. Re: High revs no power
    Apr 2012
    Gabrorne; Botswana
    Yes it is but only when it shifts into 3rd
  9. Re: High revs no power
    Dec 2009
    southampton uk
    You will notice it more in higher gear mostly when going uphill.It will get worse quickly and can suddenly fail completely.Just happened on my wifes Bora and the plate cracked from side to side
  10. Re: High revs no power
    Apr 2012
    Gabrorne; Botswana
    By plate i take it you mean the clutch will i have to replace the dmf as well coz that seems to be the general consensus in these forums
  1. power loss only at high revs
    By crashcarter in forum Audi A4 - B5 Forum - 1995 - 2002
    Last Post: 22-05-2013, 07:49 PM
  2. High revs, low power when cold
    By MudSurfer in forum A6 - S6 - RS6 - - Archive Topics
    Last Post: 28-03-2009, 03:01 PM
  3. Question Loss of power at high revs
    By regisray in forum Polo - Derby - Lupo - Fox
    Last Post: 23-06-2008, 07:53 AM
  4. epc light , esp light , low power , high revs ..help...
    By b2online in forum Audi A3 - Archive Topics
    Last Post: 06-05-2008, 11:32 PM
  5. Kangaroo-ing at low revs and Revs staying high on Gearchange.
    By Dancake in forum Passat - B5 Forum - 1997 -2005
    Last Post: 23-10-2007, 05:50 PM
