Thread: Electrical issues
  1. Electrical issues
    Jun 2013
    Dudley England
    Hi guys , first post so any help appreciated,
    got a4 cab 2003 3.0 sport, not long bought it and found few isissues
    drivers seat won't move forward or back off either switch, everything else on seat works
    alarm goes off, (no siren though) after couple mins when locked with remote or key,
    sit inside with ignition off and can hear noises as though not going to sleep,
    Roof opens fine and light goes off on dash, but close it and it closes but the windows don't close back up ant the roof
    light stays on on the dash.
    Tried manual reset loads of times
    I suspect convenience control module but not sure if,module covers all faults? I plugged a snap on scanner in and it won't communicate with seat at all, and says code 00470 for roof
    any clues? I have own bodyshop and got car with slight rear damage but roof was perfect when had it
    mark
  2. Re: Electrical issues
    Aug 2007
    Cambridge, Cambridgeshire, United Kingdom
    15 Post(s)
    Sure it says that for the roof mate? A quick gander on t'internet suggests that is Exhaust Pressure Sensor....?
  3. Re: Electrical issues
    Feb 2013
    Swindon
    You need a proper scan doing as there appears to be multiple issues. Put a friendly request out in the VCDS section for a user to help out in your area.
  4. Re: Electrical issues
    Jun 2013
    Dudley England
    Quote Originally Posted by ajrayner View Post
    Yes coming to that conclusion think I've sorted alarm if I light up the switch on door card for being towed all is well, will have good look
    at switch tomorrow, I took the ccm out from under seat no apparent damage or signs of water,
    does anyone know if ccm can cause can bus to not go to sleep? And as it anything to do with roof?
  5. Re: Electrical issues
    Jan 2011
    derby UK
    When you say CAN bus does not go to sleep what ECU is awake? CAN bus is just lost of ECU talking on wires. If you see activity then it may worth finding out what ECU is alive.
  1. Electrical Issues
    By n2w in forum Audi A4 - B5 Forum - 1995 - 2002
    Last Post: 16-06-2012, 04:12 PM
  2. Question Electrical Issues??
    By Mini Mark in forum Golf MK5 - 2004 - 2009
    Last Post: 08-03-2011, 12:40 PM
  3. Electrical Issues
    By Hangn in forum Audi A4 - B6 Forum - 2002 - 2005
    Last Post: 07-02-2010, 10:03 PM
  4. electrical issues
    By hodso in forum Towbars, Towing, Roof Boxes & Bike Racks
    Last Post: 03-03-2009, 12:30 PM
  5. Electrical ISSUEs
    By ash1322 in forum A6 - S6 - RS6 - - Archive Topics
    Last Post: 21-11-2007, 02:04 AM
