Thread: Making a Hybrid Turbo
Results 1 to 10 of 14
  1. Making a Hybrid Turbo
    Aug 2011
    Hornchurch
    What is needed to make a Hybrid Turbo?
    I fancy a project
    1.8Turbo. Stage 1 Tuned 215bhp
    l Powerflow Cat Back Exhaust l Carbonio Cold Air Intake l Forge 007P Diverter l Stage 1 Remap l Stage 2 Carbon Kevlar Clutch l 40mm Apex Lowering Springs l HZ Altezza Front skirt l HZ Altezza side skirts l HZ Altezza spoiler l Votex Rear Bumper l 19" RS6 Alloys l 312mm Brake Upgrade l 2007 S-Line Interior l
  2. Re: Making a Hybrid Turbo
    Apr 2013
    Rochester, Kent
    Quote Originally Posted by sam.bird3 View Post
    I fancy a project
    adamss24 is the man for that Sam!
    1 1 0
  3. Re: Making a Hybrid Turbo
    Feb 2013
    Swindon
    Not wanting to p**s on your chips, Sam but you'd need a piece of test kit that can spin the turbo up to 225000 rpm to ensure it's balanced. Found this out when I asked about using one of the ebay seal and bearing kits to give my turbo a service.
  4. Re: Making a Hybrid Turbo
    Aug 2011
    Hornchurch
    Oh well, there goes that idea. Lol.
    Time to cook up a new project.
  5. Re: Making a Hybrid Turbo
    Feb 2013
    Swindon
    Ha, do you ever just drive and enjoy your car...you've done plenty already!?!?
  6. Re: Making a Hybrid Turbo
    Aug 2011
    Hornchurch
    I enjoy it every day, but there's always more you can do to have MORE fun
  7. Re: Making a Hybrid Turbo
    Apr 2013
    Rochester, Kent
    I know your not meant to link but try these Sam....
  8. Re: Making a Hybrid Turbo
    Aug 2011
    Hornchurch
    But expensive for me, i'd need to pay out well over a grand for one of those as it's not just the Turbo needed, I would need a FMIC, 330cc Injectors, 3" MAF & a remap to get the true benefits from one of those turbos
  9. Re: Making a Hybrid Turbo
    london/ UK
    Most ko3s/ko4 turbo's are from transverse engines and feature a much, much larger hot side than the ko3 fitted to the 1.8T longitudinally mounted engines (a4/a6)...You will need to upgrade turbine as well if you want to flow enough for your power target, what goes in must go out ! The standard dual intercooler setup is ok for up to 250-280Bhp after that it becomes heat soaked especially when using a hybrid turbo ! Injectors, fuel pressure regulator and a uprated fuel pump,turbo + mandatory remap will get you to your target, just don't forget about brakes and suspension- when going fast you might need to stop as well as accelerate !
    1 1 0
  10. Re: Making a Hybrid Turbo
    Aug 2011
    Hornchurch
    Suspension is all done, I have a 320mm brake upgrade planned, I have all the parts apart from the caliper carriers but I'm getting these on Friday from bobfish so will hopefully fit it all next weekend.
  1. A6 Hybrid!
    By theskyfox in forum Audi A6 - C7 Forum - 2011- 2018
    Last Post: 21-03-2013, 09:59 AM
  2. Q5 Hybrid
    By EssexGonzo in forum Q5
    Last Post: 10-08-2012, 01:07 PM
  3. Please Help Turbo decided to die: Hybrid advice?
    By keemaklan in forum Audi A4 - B7 Forum - 2005 - 2008
    Last Post: 20-04-2011, 03:26 PM
  4. hybrid turbo
    By boostin in forum Golf - Jetta - Vento - Bora - Archive Topics
    Last Post: 20-10-2007, 10:04 AM
  5. MK3 TDI turbo dying... remap or hybrid turbo?
    By leoninanegg in forum Golf MK3 - 1993 - 1999
    Last Post: 15-06-2007, 08:48 PM
