Thread: Sudden power loss/hesitation
Page 1 of 5 123 ... LastLast
Results 1 to 10 of 41
  1. Sudden power loss/hesitation
    Leicestershire
    Hi guys,
    I'm experiencing some quite worrying problems today.
    Car:- 3.0tdi Quattro bmk
    Starting from the beginning I had a service on Monday oil change using quantum platinum, air filter,I ran some engine flush, some archoil fuel treatment, and some archoil oil additive.
    My fuel was just under half a tank and today it got low to the point of fuel light on and 15 miles left to empty I then topped up to full tank with v power.
    Since Monday i had this intermittent problem when flooring it the car would have a sudden instant loss of power all dials on dash would go off for a split second - esp light flashed and brake warning would flash 3 times, mmi would go off and restart to the original radio station it was on when car was first started, then the usual cycle of dash lights would happen ... At the same time the car would drive normally instantly ....
    Today however it got worse, a lot worse.
    It started happening at lower speeds, or when hitting a large pot hole. Can be replicated too.
    So I decided to change fuel filter and cleaned maf. Still happening and car's gear changes seem really hesitant - seems to drive quite rough too.
    At one point the entire engine shut down with power steering loss too. Restarted car and it drove fine again albeit kind of rough.
    I'll try get a video of the dash sequence when this happens when i get a chance.
    I immediately done a vcds scan and will post the faults...however upon clearing them they haven't come back bar one...
    Any ideas?
    Fault codes are here:--
    the only one that has come back after clearing is the alarm horn and the a/c sensor. although the glow plug one seems to be coming back after a few weeks of driving as does the intake manifold runner control
    the map is a new one that i haven't seen before since owning this car.
    I'm begging to think I've either knocked something near/around the air filter box when doing that or it's some ecu dying somewhere
    Code:
    Address 01: Engine        Labels: Redir Fail!   Part No SW: 4F0 910 401 L    HW: 4F0 907 401 A
       Component: 3.0L V6TDI  G000AG  0020
       Revision: --H01---    Serial number:
       Coding: 0011772
       Shop #: WSC 02335 785 00200
       VCID: 254BEF4DECFA271
    6 Faults Found:
    17055 - Cylinder 1 Glow Plug Circuit (Q10)
                P0671 - 001 - Electrical Fault
                 Freeze Frame:
                        RPM: 0 /min
                        Torque: 249.6 Nm
                        Speed: 0.0 km/h
                        Duty Cycle: 1.0 %
                        Voltage: 8.89 V
                        Duty Cycle: 15.0 %
                        Temperature: 12.6°C
                        Bin. Bits: 00110000
    17056 - Cylinder 2 Glow Plug Circuit (Q11)
                P0672 - 001 - Electrical Fault
                 Freeze Frame:
                        RPM: 0 /min
                        Torque: 249.6 Nm
                        Speed: 0.0 km/h
                        Duty Cycle: 1.0 %
                        Voltage: 8.89 V
                        Duty Cycle: 15.0 %
                        Temperature: 12.6°C
                        Bin. Bits: 00110000
    17058 - Cylinder 4 Glow Plug Circuit (Q13)
                P0674 - 001 - Electrical Fault
                 Freeze Frame:
                        RPM: 0 /min
                        Torque: 249.6 Nm
                        Speed: 0.0 km/h
                        Duty Cycle: 1.0 %
                        Voltage: 8.89 V
                        Duty Cycle: 15.0 %
                        Temperature: 12.6°C
                        Bin. Bits: 00110000
    19591 - Intake Manifold Runner Control
                P3135 - 001 - Lower Stop not Reached - Intermittent
                 Freeze Frame:
                        RPM: 756 /min
                        Torque: 97.5 Nm
                        Speed: 0.0 km/h
                        Voltage: 13.53 V
                        Duty Cycle: 12.2 %
                        Duty Cycle: 80.9 %
                        Duty Cycle: 80.9 %
                        Temperature: 87.3°C
    18061 - Please check DTC Memory of ABS Controller
                P1653 - 002 -  - Intermittent
                 Freeze Frame:
                        RPM: 3465 /min
                        Torque: 62.4 Nm
                        Speed: 30.2 km/h
                        Duty Cycle: 35.9 %
                        Voltage: 13.68 V
                        Bin. Bits: 00101100
                        Torque: 405.6 Nm
                        Temperature: 94.5°C
    16620 - Manifold Pressure / Boost Sensor (G31)
                P0236 - 001 - Implausible Signal - Intermittent
                 Freeze Frame:
                        RPM: 147 /min
                        Torque: 195.0 Nm
                        Speed: 13.4 km/h
                        Voltage: 2.040 V
                        Voltage: 11.70 V
                        Absolute Pres.: 979.2 mbar
                        Temperature: -17.1°C
                        Absolute Pres.: 1091.4 mbar
    Readiness: 0 0 0 0 0
    Address 03: ABS Brakes        Labels: 4F0-910-517.lbl
       Part No SW: 4F0 910 517 E    HW: 4F0 614 517 A
       Component: ESP8 quattro    H03 0010
       Revision: 00000000    Serial number: 00000000000000
       Coding: 0004492
       VCID: 2649E84191FC2C9
    1 Fault Found:
    00532 - Supply Voltage B+
                 Freeze Frame:
                        Fault Status: 00100010
                        Fault Priority: 2
                        Fault Frequency: 1
                        Reset counter: 141
                        Mileage: 161754 km
                        Time Indication: 0
                        Date: 2013.06.20
                        Time: 14:31:00
                 Freeze Frame:
                        Hex Value: 0x2D80
                        Hex Value: 0x4006
                        Hex Value: 0x125E
                        Hex Value: 0x009F
                        Hex Value: 0x00FF
    Address 08: Auto HVAC        Labels: 4F0-910-043.lbl
       Part No SW: 4F0 910 043     HW: 4F2 820 043 B
       Component: KLIMABETAETIGUNGH11 0100
       Revision: 00000022    Serial number: 00000000036552
       Coding: 0001046
       VCID: DBBF09B51A3E211
    1 Fault Found:
    00256 - A/C Pressure/Temperature Sensor (G395)
                004 - No Signal/Communication
                 Freeze Frame:
                        Fault Status: 01100100
                        Fault Priority: 3
                        Fault Frequency: 7
                        Reset counter: 95
                        Mileage: 160414 km
                        Time Indication: 0
                        Date: 2013.05.20
                        Time: 19:59:59
    Address 17: Instruments        Labels: 4F0-910-xxx-17.lbl
       Part No SW: 4F0 910 900 A    HW: 4F0 920 950 L
       Component: KOMBIINSTR. M73 H08 0630
       Revision: 00200000    Serial number: 4I1152L74
       Coding: 0001443
       Shop #: WSC 00000 000 00000
       VCID: 1E39C0A1C9ACF49
    1 Fault Found:
    00473 - Control Module for Elect. Park/Hand Brake (J540)
                 Freeze Frame:
                        Fault Status: 00100100
                        Fault Priority: 2
                        Fault Frequency: 1
                        Reset counter: 105
                        Mileage: 161054 km
                        Time Indication: 0
                        Date: 2013.06.06
                        Time: 15:31:26
    Address 19: CAN Gateway        Labels: 4F0-910-468.lbl
       Part No SW: 4F0 910 468 A    HW: 4F0 907 468 B
       Component: Gateway         H09 0030
       Revision: 09          Serial number: 080080471801F6
       Coding: 6CFE53C41B1104
       VCID: 2757E54596F6351
    1 Fault Found:
    01303 - Telephone Transceiver (R36)
                 Freeze Frame:
                        Fault Priority: 3
                        Fault Frequency: 1
                        Reset counter: 120
                        Mileage: 161297 km
                        Time Indication: 0
                        Date: 2013.06.11
                        Time: 12:25:12
    Address 46: Central Conv.        Labels: 4F0-910-289.lbl
       Part No SW: 4F0 910 289 E    HW: 4F0 907 289 E
       Component: Komfortgeraet   H14 0090
       Revision: 00900014    Serial number: 01000491320000
       Coding: 0008435
       Shop #: WSC 00137 211 56823
       VCID: 2C5D1A698F10169
       Part No: 1K0 951 605 A
       Component: LIN BACKUP HORN H01 1201
       Part No: 4F0 910 177
       Component: Innenraumueberw.H01 0010
    2 Faults Found:
    01134 - Alarm Horn (H12)
                012 - Electrical Fault in Circuit
                 Freeze Frame:
                        Fault Status: 01101100
                        Fault Priority: 3
                        Fault Frequency: 254
                        Reset counter: 101
                        Mileage: 158953 km
                        Time Indication: 0
                        Date: 2013.03.21
                        Time: 12:10:49
                 Freeze Frame:
                        Fault Priority: 3
                        Fault Frequency: 4
                        Reset counter: 141
                        Mileage: 0 km
                        Time Indication: 0
    Address 53: Parking Brake        Labels: 4F0-910-801.clb
       Part No SW: 4F0 910 801     HW: 4F0 907 801
       Component: EPB  C63C0030   H03 0030
       Revision: C63C0030
       Coding: 0000321
       Shop #: WSC 00899 210 12701
       VCID: DDBB07AD042A2F1
    1 Fault Found:
    01316 - ABS Control Module
                013 - Check DTC Memory - Intermittent
                 Freeze Frame:
                        Fault Status: 00101101
                        Fault Priority: 3
                        Fault Frequency: 1
                        Reset counter: 141
                        Mileage: 161752 km
                        Time Indication: 0
                        Date: 2013.06.20
                        Time: 14:31:02
                 Freeze Frame:
                        Voltage: 13.15 V
                        Count: 236
    Address 77: Telephone        Labels: 4E0-910-336.lbl
       Part No SW: 4E0 910 336 B    HW: 4E0 862 335
       Component: Handyvorb2      H10 0080
       Revision: 00000000    Serial number: 00000007515894
       Coding: 0010900
       VCID: 2143FB5DF8D2CB1
    1 Fault Found:
                 Freeze Frame:
                        Fault Priority: 7
                        Fault Frequency: 1
                        Reset counter: 135
                        Mileage: 161638 km
                        Time Indication: 0
                        Date: 2013.06.17
                        Time: 17:45:23
  2. Re: Sudden power loss/hesitation
    Nov 2012
    Somerset UK
    So just mechanical changes recently and you're suffering from what seems to be multiple electrical problems?
    Have you checked your battery connection and voltage from the alternator?
    Erm what's the one that's come back...don't leave us in suspenders!
  3. Re: Sudden power loss/hesitation
    Leicestershire
    not checked battery connection or voltage yet. I'll do it with vcds until I can find my lost multimeter or buy a new one over the next few days...
    Quote Originally Posted by MarkTM View Post
  4. Re: Sudden power loss/hesitation
    Nov 2012
    Somerset UK
    Just ordered my VCDS today, but even if I'd had it I'd test the battery/alternator and glow plug connectors first.
    You can still do it as it's still light out!
  5. Re: Sudden power loss/hesitation
    Jan 2011
    Stafford, UK
    Quote Originally Posted by techfreak View Post
    Hi guys,
    Any ideas?
    Sounds like a loose connection somewhere.
    BTW. Audi state not to use fuel additives, oil aditives or engine flush.
    When did you last drain / change your fuel filter ?
    2009 - A6 2.7 TDI (CANA) - S Line - Avant (Multitronic) Daytona Grey.
    Ross-Tech - http://www.ross-tech.com/vcds/tour/main_screen.html
    Screen capture - FastStone Screen Capture - The Best Screen Capture Software
    2 0 0
  6. Re: Sudden power loss/hesitation
    Leicestershire
    Quote Originally Posted by royclark View Post
    Yes I'm beginning to think loose connection.
    Happened again twice on a short 3/4 mile journey soon as I hit a slight bump in the road - all power out and instantly back on.
    I changed the fuel filter this evening after this started happening as a first point of call.
    Why do Audi state that never to use those things? First I've heard of that and always used them inc on my last 4 vag group cars with no ill effect and positive results.
    Audi A6 C6/4F 3.0 V6 TDI Quattro S-line - BMK
  7. Re: Sudden power loss/hesitation
    Jan 2011
    Stafford, UK
    I'm just reading up on that in my hand book.
    No biodiesel. = damage to fuel system.
    Do not mix fuel additives with the diesel.
    Diesel must conform with EN590. Have a cetain number (CN) of at least 51.
    No additives should be used with engine oil. Any damage caused by such additives will not be covered by warranty.
  8. Re: Sudden power loss/hesitation
    Nov 2012
    Somerset UK
    My bits added in bold
    I'me just reading up on that in my hand book.
    No biodiesel. = damage to fuel system. Same applies to all 'normal' diesels surely?
    Do not mix fuel additives with the diesel. All Audi drivers best steer clear of Shell V-Power Nitro+ then!
    Diesel must conform with EN590. Have a cetain number (CN) of at least 51. Applies to all consumer automotive diesel sold in the UE
    Tech is your car in warranty or does it have FASH meaning if there's a failure you may be able to get Audi to contribute?
  9. Re: Sudden power loss/hesitation
    131 Post(s)
    1979 Post(s)
    Have you had any signs of water inside the car? We are seeing more and more 4F's with the electronics boxes in the plenum chamber doubling up as goldfish bowls and it causes havoc and those fault codes point towards a wet ECU. Mind you you could just have the usual faulty manifold and need some new glow plugs.
  10. Re: Sudden power loss/hesitation
    Nov 2012
    Somerset UK
    Crasher does the water problem apply equally to saloons as estates?
    Only asking as thought it was only Avants...don't know what Tech has though.
  1. Question Sudden loss of power
    By jwturpin in forum Passat - B6 Forum - 2005 - 2010
    Last Post: 04-07-2010, 12:16 PM
  2. Question Sudden loss of power
    By cadoc in forum Audi A3 - 8L - 1996 - 2003
    Last Post: 26-11-2009, 09:43 PM
  3. Please Help Sudden Loss Of Power
    By jonjonwoohoo in forum Golf MK4 - 1999 - 2004
    Last Post: 08-08-2008, 08:37 PM
  4. Sudden Loss of Power
    By shaz75 in forum Audi A4 - B5 Forum - 1995 - 2002
    Last Post: 11-03-2008, 08:57 PM
  5. Sudden loss of power
    By shaz75 in forum Audi A4 - B6 Forum - 2002 - 2005
    Last Post: 10-03-2008, 03:56 PM
