Thread: Media Interface not recognised when plug iphone in Audi Q7
Results 1 to 10 of 14
  1. Media Interface not recognised when plug iphone in Audi Q7
    Apr 2013
    Leeds
    I cant get my Iphone working through the MMi/AMI on my Audi Q7 (57 plate) so i can play music.
    The Bluetooth connection to the iphone works ok and i can make and receive calls in the car.
    The cable is plugged into the car (under the arm rest) and when i connect my iphone to it, it simply doesn't come up.
    This same iphone worked on my A6 56 plate.
    I have the 2g MMI High system.
    Do i need to update anything or can anyone tell me how ot get it working please?
    Thanks.
  2. Re: Media Interface not recognised when plug iphone in Audi Q7
    46 Post(s)
    Do you have AMI or AUX?
    Have you pressed Source in the MEDIA menu?
  3. Re: Media Interface not recognised when plug iphone in Audi Q7
    Apr 2013
    Leeds
    AMI. Not tried it through the AUX.
    The connection is under the arm rest for the AMI.
    Yes, once iphone plugged in, i go to Media then choose source. I can then choose between CD or Interface. CD works but when i click on interface it says no device found (or something along those lines).
  4. Re: Media Interface not recognised when plug iphone in Audi Q7
    46 Post(s)
    Which cable are you using, does it have any coloured collars around the AMI end?
    Could you post a pic as I've never seen the AMI location in a Q7 before, bit odd under the armrest! nvm just googled it
    It wouldn't hurt to get a fault code scan, the unit could be faulty. Have you tried any other devices?
  5. Re: Media Interface not recognised when plug iphone in Audi Q7
    Apr 2013
    Leeds
    Cable is black. I have also tried the cable with the blue around the collar. Neither work. Used a portable Code reader and nothing comes up.
    will get a pic taken later on (once wife back with car!!)
  6. Re: Media Interface not recognised when plug iphone in Audi Q7
    46 Post(s)
    Ideally you would need vcds to scan it, if you look at the map in my signature there should be someone in your area willing to help.
    Have you tried any other devices? USB stick etc?
  7. Re: Media Interface not recognised when plug iphone in Audi Q7
    Apr 2013
    Leeds
    I do have vcds - father in law cant find his cable tho!!!
  8. Re: Media Interface not recognised when plug iphone in Audi Q7
    46 Post(s)
    Thats no good! Have a look anyway, no harm in scanning anyway just incase.
    Could you remove the AMI unit and check the connections at the rear?
  9. Re: Media Interface not recognised when plug iphone in Audi Q7
    Apr 2013
    Leeds
    No, im not very practical to be honest!!... was hoping a software update might be the answer - i work in IT - so would feel much easier doing this then anything practical!!
    Also, noticed that a couple of the buttons on the mmi are stiff/sticking.
  10. Re: Media Interface not recognised when plug iphone in Audi Q7
    46 Post(s)
    I would be trying this Important ami update online DOWNLOAD and theres no harm in trying.
    You will need your AMI->USB lead tho and a USB drive.
    My MMI buttons stick, particularly the TEL button, done it ever since I got the car in 2009 and have just learned to live with it!
  1. Iphone Interference on the RCD310 through the media interface
    By normski-foad in forum Golf MK6 - 2009 - 2013
    Last Post: 19-08-2011, 11:03 AM
  2. Multi Media Interface For Audi A3 RNS-E
    By a3lover in forum Audi A3 - 8P - 2004 - 2012
    Last Post: 10-11-2010, 09:40 AM
  3. Replies: 12
    Last Post: 07-05-2010, 11:19 AM
  4. Question Media Interface on MK 6 Golf with RCD 310
    By Mav0372 in forum In Car Entertainment
    Last Post: 27-02-2009, 08:52 PM
  5. Question Audi Multi Media Interface MP3 problems
    By kit_kat_999 in forum In Car Entertainment
    Last Post: 29-11-2008, 04:06 PM
