Thread: 2.4 diesel T4 Caravelle Panel Van, what to look for?
  1. 2.4 diesel T4 Caravelle Panel Van, what to look for?
    Aug 2007
    Hello everyone, I just thought i would introduce myself.
    My name is Matt, and am new to this site.
    I am currectly looking to buy a VW T4 caravelle panel van, 2.4 diesel.
    Does anyone know the specs of this model as i am going to view one next week and would like to know what it should and shouldn't have and faults to look for?
    For instance should it have electric windows etc?.
    It's a 2.4 diesel Caravelle Panel van, 1994 M reg, 100,000 miles and one owner
    I would appreciate any help
    Many thanks
    Matt
  2. Re: 2.4 diesel T4 Caravelle Panel Van, what to look for?
    Aug 2007
    London
    My main concern would be with the state of the engine. These vans should go on for miles if properly looked after, so try and get as much info as poss on servicing etc. When was the cambelt last done?
    When you test drive it, make sure that the engine is cold (ie the seller hasn't warmed it up prior to your arrival). Check for any smoke. Put the stationary van in neutral, and rev it up to about 3000 revs. Get someone to check for any smoke coming out the back. Black or white smoke can indicate fuel fuel probs, blue smoke oil. Hope that helps.
  3. Re: 2.4 diesel T4 Caravelle Panel Van, what to look for?
    Aug 2007
    Thanks Willard, thats great.
    do you know if caravelle panel vans should have electric windows like the MPV caravelles do ?
  4. Re: 2.4 diesel T4 Caravelle Panel Van, what to look for?
    Aug 2007
    London
    As far as I'm aware a Caravelle shouldn't have any panels on it at all. If it is a panel van then it sounds like it is a Transporter not a Caravelle.
    Both vans are essentially the same body shape and can have similar engines (caravelles tend to be 2.5TDI). They are both classed as being from VW T4 range. However the Transporter is a commercial vehicle (ie panel van) and the caravelle is classed as an MPV, ie usually 8 seater, leccy windows, few more whistles and bells. Think huge family vehicle.
  5. Exclamation Re: 2.4 diesel T4 Caravelle Panel Van, what to look for?
    Aug 2007
    first thing is mainly check the engine , as vw's do have a tapid problem , as they r hydrolic , and if u purchase it , first thing to do is get the cam belt changed.
  1. caravelle alloys
    By veedubbed in forum Touran - Sharan - Caravelle
    Last Post: 30-08-2007, 10:54 AM
  2. breaking a t4 caravelle
    By WEEARETHEPEOPLE in forum The Commercial Range
    Last Post: 16-08-2007, 06:19 PM
  3. T4 1999 Caravelle 2.5 TDI
    By andy123 in forum New Member Introductions
    Last Post: 13-07-2007, 07:45 PM
  4. VW Caravelle TD 03 plate
    By malkyh in forum The Commercial Range
    Last Post: 06-07-2007, 10:27 PM
  5. Caravelle Sat Nav
    By k999dun in forum Chat - Completely Off Topic
    Last Post: 22-10-2006, 11:23 AM
